Author Topic: Points vs Electronics  (Read 1857 times)
Offline Tropicalcats
  • Don't Ever, Ever Give Up
« on: June 01, 2006 - 06:05:55 PM »
Just looking for some input on the Points vs electronic egnition.
The question came up the other day during my 383 rebuild. I want to keep as stock as possible but I would think the electronic egnition is the way to go. What say you.
 :feedback:
SOLD
Re: Points vs Electronics
« Reply #1 on: June 01, 2006 - 06:12:14 PM »
  :iagree:  :iagree:  :iagree:  :iagree:
  It is more efficient, and you won't have to be messing with the dwell. Go electronic.  :thumbsup:
Offline ShelbyDogg
« Reply #2 on: June 01, 2006 - 07:11:35 PM »
Go electronic, hide the orange wire and ECU, and it'll look stock.  It even now uses a single ballast resistor.
You could even use a modified distributor that uses a GM HEI module screwed to the underside of the distributor that hides it even better.
Offline Robb
« Reply #3 on: June 01, 2006 - 07:44:19 PM »
Check out pertronix  DIY  conversion of your existing distributor.     I used this on my 68 convertible and its easy and runs well and looks proper.
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
Offline ShelbyDogg
« Reply #4 on: June 01, 2006 - 08:40:51 PM »
But Robb,  If you run that petronix, 1. it's expensive 2. you can't go to the auto parts store and buy a part to get your butt home. :bigsmile:
Offline 70RTdroptop
  • 1970 Challenger R/T 440-SixPack
« Reply #5 on: June 01, 2006 - 09:12:45 PM »
Go electronic. I used to be a stickler for the stock look, but after recently installing the MSD set-up and enjoying the dramatic power gains, I've kind of relaxed my views a little bit. Besides, if you do sell the car, it's easy enough to go back to points and the stock look.
1970 Dodge Challenger R/T 440-6 convertible
1966 Ford Mustang convertible  - numbers matching (wife's car )
Oldschool
« Reply #6 on: June 01, 2006 - 09:37:24 PM »
Electronic all the way............    :cooldancing:
Offline 71340RT
« Reply #7 on: June 01, 2006 - 11:36:47 PM »
Electronic is the only way to go. No more burned points and the dwell will not change. I put pertronix on my Cuda and the only problem is parts are not avalible at your local parts store.
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
« Reply #8 on: June 02, 2006 - 12:02:03 AM »
I have had problems with Pertronics in the past
« Reply #9 on: June 02, 2006 - 05:39:46 AM »
What type of problems?
What would you recommend Chryco?
SOLD
Offline ShelbyDogg
« Reply #10 on: June 02, 2006 - 07:59:16 AM »
The only possible problem is a NO-SPARK condition and a NO-SPARE in the glove box.
 :bigsmile:
Offline Robb
« Reply #11 on: June 02, 2006 - 06:59:20 PM »
I think I paid 39$ for the pertronix ?   :angelwings:
and you have to admit anymore...   there arent as many things at the auto parts store that you can buy the same day as you used to...     I spend most of my downtime due to waiting on parts rather than parts waiting on me   :cooldancing:
your point is taken though  :bigsmile:
« Reply #12 on: June 02, 2006 - 11:44:27 PM »
I have seen them be intermittent & have trouble starting
Offline Mopar73340
« Reply #13 on: June 03, 2006 - 08:02:59 AM »
I also have a friend who has had problems with it.
