Author Topic: Cursed transmission!!  (Read 702 times)
Offline torredcuda
  • Epping NH joined 11/23/03
« on: June 02, 2006 - 06:03:30 PM »
The freshly rebiult trannys coming out of the `69 tomorrow and I swear it`s gotta be cursed!This is the same Fairbanks transmission I pulled from my `72 after 3 attempts by them to biuld me one that worked right but I was never happy with the way it shifted,always flared a bit on the 2-3 shift.I took it for a test run and to get some better pics( you guys are slacking not geting on me for new pics of the `69  :picture: ) and the 1-2 shift was solid but it would not shift into third gear.Got it back into the driveway and reverse was slow going in also.After doing a line pressure test we think it is a bad high gear seal which means pulling  it out and apart to fix,I`m not a happy camper!Hopefully that is all it is and we can have it up and running and soon as the new seal shows up which should be Monday.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline Hemi Challenger
  • Nothing run better then a HEMI
Re: Cursed transmission!!
« Reply #1 on: June 02, 2006 - 06:09:16 PM »
 :iagree: Yes we are so Who is your Tranmission man or you doing it yourself, If you are doing it  yourself   Good Luck                                                            :useless:
Offline torredcuda
« Reply #2 on: June 02, 2006 - 06:19:26 PM »
My buddy gave me a hand doing it as he`s done a few powerglides and is a pretty good mechanic.Before the next rebiuld we are making the tools to check everything we can BEFORE installing it in the car so hopefully this won`t happen again!Car is on jacks in the garage so now you`ll have to wait another week for pics.  :working:  :eek4:
Jeff
kudakidd
« Reply #3 on: June 05, 2006 - 10:46:33 AM »
That's what happens when you go with a slush box for a transmisson! :roflsmiley: J/K
Offline torredcuda
« Reply #4 on: June 05, 2006 - 04:50:13 PM »
I got smart and yanked it out of my`72 to put in the four speed but figured I`d throw it in the 69 for consistency seeing how it`s more of a drag car.  :banghead:
Jeff
Offline 422STROKER
  • Member Since 6/3/06
« Reply #5 on: June 05, 2006 - 04:57:28 PM »
If you give up I've always had good luck w/Lowell auto trans  they've done a few for me over the years unfortunately! Decent money esp for a bench job
Good Luck
Tom
Tom
