Author Topic: Fender Tag Help  (Read 1248 times)
Offline Ravage
  • 1974 318 'Cuda
Fender Tag Help
« on: June 02, 2006 - 08:03:21 PM »
There is one entry in my fender tag that I just can't track down.It's "442".Tag is pretty clean so there is no mistaking it.In case you get curious ,the complete decode is...
VIN:                      BS23G4B179441
YEAR:                     1974
Car Line and Model:       Plymouth - 'Cuda
Price Class:              Special
Body Type:                2 Door Hardtop
Engine:                   318 CID 1-2BBL  8 CYL
Assembly Plant:           Hamtramck, MI
Sequence Number:          179441
R11        AM Radio - Music Master 2-Watt
V6X        Longitudinal Tape Sport Stripes - Black
L2         Assmebly line 2 (1974 only)
442        The provided code/year combo is currently undocumented
M26        Wheel Lip Mouldings
M31        Door/Quarter Belt Mouldings
M88        Deck Lid Moulding Treatment
N76        Coolant Recovery System
N85        Tachometer
G54        Left Hand Outside Mirror - Remote/Chrome/RAC
J25        3-Speed Windshield Wipers - Variable
J52        Hood Release - Instrument Panel Mounted
J54        Sport Hood
M21        Drip Through Mouldings
M25        Body Sill Mouldings
V1X        Full Vinyl Roof - Black
U          Build to Specifications for U.S.A. Order
B41        Front Disc Brakes, Rear Drum Brakes
C16        Console
C56        Bucket Seats
G11        Tinted Glass - All Windows
E44        318 CID  8 CYL  1-2BBL  150 hp
D34        Standard Duty Automatic Transmission
A22        Production Date - 10/22/1973
KT5        Paint Code - Sienna Metallic
000        Upper Door Frame - Full Door Panel
A6XW       Trim Grade - A Class
           Trim Style - Vinyl Bucket Seats
           Trim Color - White and Black
"I flipped off a box of kittens once..." (Tycho on being evil)
Offline Super Blue 72
    • Phil's Super Blue '72
Re: Fender Tag Help
« Reply #1 on: June 02, 2006 - 10:13:20 PM »
 ??? That's wierd.  442?  I know you said that it was pretty clear on the tag it is 442 but even if it was off alittle, like A42 that comes out to Dart Spring Special Package A which doesn't make sense on a Challenger.
I checked out a 1974 Barracuda brochure but they don't list the codes.
http://www.stockmopar.com/1974-plymouth-barracuda-duster-valiant-brochure.html
Sorry, hope you find the code!
Alaskan_TA
Re: Fender Tag Help
« Reply #2 on: June 02, 2006 - 10:23:34 PM »
It is not an option code, 1974 Hamtramck tags I have looked at so far vary, I have seen numbers as low as 19 and as high as 944 in the same tag position.
I would like to know the meaning myself.  ???
Barry
