Author Topic: Could it be Too Lean ?  (Read 931 times)
Offline chevyconvert
  • HvacMan
  • Member since November 04, 2005
« on: June 02, 2006 - 08:19:52 PM »
ok may be a dumb question, but better safe than sorry.
IF my 440- six pack car is only operating with it's 350 cfm center carb, could I damage the engine under hwy. or performance situations by it running too lean?
Or would it just run short of gas and die? Is that different than running lean?
I have not confirmed that my outboards are opening or not.
Running ok, but not scarey fast.
Took a Mopar neighbor who used to own a 440-6 'cuda for a ride yesterday, and he didn't feel they were opening or the timing is retarded too much.(not scarey fast)
Anyways...any danger in regards to Lean operation?
Plugs look ok, but they're new.
Eric
'70 Hemi Orange RT/SE 440 Six Pack Pistol-Grip 4 speed
Bay Area California
Re: Could it be Too Lean ?
« Reply #1 on: June 02, 2006 - 11:46:12 PM »
air flow is related to fuel flow so if you are for some reason only running the center carb that will not make it lean as long as the jets in the carb are rated correctly for the air flow through the carb
  • HvacMan
« Reply #2 on: June 02, 2006 - 11:53:42 PM »
ok...
so (and I admit I've had a few ales) non technically speaking.. I won't hurt the engine runnin' it this way?
Eric
Bay Area California
« Reply #3 on: June 02, 2006 - 11:58:36 PM »
nope
 where the the secondaries connected to ?
there are 2 ports side by side , the upper one with the Tube is for the dist , the lower is the outbards , it will not work correctly hooked the other way
  • HvacMan
« Reply #4 on: June 03, 2006 - 12:11:24 AM »
took a couple of minutes in the garage, but here's how she's sitting now..
(disconnected the breather hose for clarity)
Eric
Bay Area California
« Reply #5 on: June 03, 2006 - 11:02:55 AM »
looks right to me
  • HvacMan
« Reply #6 on: June 04, 2006 - 09:03:40 AM »
Thanks CP.
since you can't tell if the outboards are opening with it in the garage, whats the best way to know if one or both are opening?
I remember someone posting about putting a paper clip on the vacuum shafts, running it and seeing if they get pushed down...is that the best way?
Eric
Bay Area California
« Reply #7 on: June 04, 2006 - 10:13:29 AM »
Paper clip works
I cannot see a reason why they wouldn`t be opening unless there si a problem with the linkage on the other side or the diaphragms are torn inside the secondaries  , you should be able to hear the secondaries open , the induction noise with them all open is huge
