Author Topic: ECU Mounting  (Read 1011 times)
Offline Plum6Pak
  • Plum6Pak
ECU Mounting
« on: June 03, 2006 - 08:37:19 AM »
I've read somewhere on the forum but can't find the link that shows where everyone mounted their ECU or control box. I have the MSD unit and wondered where everyone has installed theirs. Pictures would be great. Just trying to get some ideas, I have a few ideas of my own but don't want to rule anything out.
Offline Carlwalski
Re: ECU Mounting
« Reply #1 on: June 03, 2006 - 08:50:04 AM »
Here's mine, the % seem to mount them there.  :thumbsup:
 :2cents:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline Plum6Pak
  • Plum6Pak
Re: ECU Mounting
« Reply #2 on: June 03, 2006 - 09:07:23 AM »
Thanks Carl, that works well and looks good too but mine is a little big for that spot, maybe the B body is different but I don't have the room right there. Here are some pictures of where I was considering, any other suggestions will be appreciated.
Offline Mopar73340
Re: ECU Mounting
« Reply #3 on: June 03, 2006 - 09:25:49 AM »
I don't have a pic handy, but I mounted mine between the emergency brake pedal and the brake/clutch pedal under the dash. Had to make a bracket and drill a hole or 2 but it's out of the heat and out of the way.
« Last Edit: June 03, 2006 - 09:35:23 AM by Mopar73340 »
Re: ECU Mounting
« Reply #4 on: June 03, 2006 - 09:33:31 AM »
From memory, someone mounted one under the passenger's side dash to keep it hidden, and I believe someone else mounted it under the battery tray.
Re: ECU Mounting
« Reply #5 on: June 03, 2006 - 11:04:30 AM »
I have mounted them on the firewall l ike NZ , I have also used the 73-74 mount bracket & I have mounted them in the interior of the car & under the battery tray as well depending what look the customer is after
Offline Carlwalski
Re: ECU Mounting
« Reply #6 on: June 03, 2006 - 11:13:58 AM »
Sorry Glen, I should have read your post a little better.
Under the battery sounds good and also interior mounted for less engine bay items.  :cheers:
Offline Robb
Re: ECU Mounting
« Reply #7 on: June 03, 2006 - 03:48:32 PM »
I have my MSD 6AL under the battertray on my eBody.
very unobtrusive  :bananasmi
I made some stiff brackets  so that it used existing bolt holes and then hangs the unit properly. (waterresistance and heat dissappation per instructions of MSD)
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
Offline Plum6Pak
  • Plum6Pak
Re: ECU Mounting
« Reply #8 on: June 04, 2006 - 06:59:34 AM »
Thanks everyone, your ideas have all been very helpful. I'll post a picture once I've made my choice where to mount this.
