Author Topic: Small block main bearings  (Read 1104 times)
Offline mrbill426
    • All Around Mopars
« on: June 04, 2006 - 08:40:03 PM »
 :1zhelp: I am a little confused about interchangeability of small block main bearings.  As far as I know the crank journals of the 318 and 340 are the same size, so I would think the main bearings would be the same too.  I have had a set of clevite 77s for a while that I thought were for a 340 but when I looked up the part number in the index my newly acquired master bearing catalog it says they are for later ('74 and up) 318s only.
Best I can tell the only difference from these (#MS-1344P) and the "340" mains (#MS-963P) is that these are full groove on all bearings, while the 340 ones are half groove except for the rear main which is full.  The rod bearing numbers are the same for both engines.  Am I missing something?   :dunno:  Is there any reason why I should NOT run full grooved mains in a 340?  I ran them in a 383 without any problems, but that was a big block, perhaps the small block has oiling issues?  I will be using a deep sump and HV pump.
 :working:
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
Re: Small block main bearings
« Reply #1 on: June 04, 2006 - 09:08:29 PM »
I always use full groove brgs in any rebuild I do
Offline mrbill426
    • All Around Mopars
« Reply #2 on: June 04, 2006 - 09:21:13 PM »
So, I am correct to assume that even though the clevite book singles the full grooved set out as being for later 318s, they will work fine in a 340?  Wonder why they opt for half grooves in a "performance" 340, and fulls in a smogger 318  ???
MOPAR or NO car!
« Reply #3 on: June 04, 2006 - 11:15:00 PM »
the only other thing to watch is the size of the thrust surface , it may have been made larger in the later block , I cannot think of qany other reason not to use them
Offline mrbill426
    • All Around Mopars
« Reply #4 on: June 04, 2006 - 11:51:44 PM »
Okay, I'll check that.  Do you mean the width of the bearing, flange to flange, or the depth (or height) of the flanges?
MOPAR or NO car!
« Reply #5 on: June 04, 2006 - 11:52:21 PM »
height
Offline mrbill426
    • All Around Mopars
« Reply #6 on: June 05, 2006 - 12:01:05 AM »
I got ya, easy to check  :thumbsup:
Will let you know...
 :working:
MOPAR or NO car!
