Author Topic: Fuel Sending Unit Repair '71 Challenger  (Read 1297 times)
Offline dlrogers
  • 1971 Challenger 383
« on: June 04, 2006 - 10:42:23 PM »
Fuel gauge hasn't worked since I got the car. Fixed it today but Dodge service manual not specific enough about removal of unit so I thought I'd put it in here. Remove left side rear heat shield by tank. Remove ground strap and sender wire. Rotate sender unit locking ring anti-clockwise (should have proper tool but there was no problem without it). Remove unit and service as required. My problem was a holed float which I soldered up to make air tight again. Reassemble in reverse order checking that float arm is able to move vertically.
Cheers
Bay of Islands, New Zealand
Offline 4Cruizn
  • HEMI FISH
Re: Fuel Sending Unit Repair '71 Challenger
« Reply #1 on: June 04, 2006 - 10:45:34 PM »
Nice work!!   :thumbsup:
