Author Topic: were to find a low fuel relay for 1970 dodge challenger???  (Read 2364 times)
Offline 1fastsixpack
Mine is fryed!!  I have made some calls but know luck so far, Any one know were to get one??
« Last Edit: June 05, 2006 - 02:15:21 PM by 1fastsixpack »
Offline ArcticCuda
    • Pepe
Re: were to find a low fuel relay for 1970 dodge challenger???
« Reply #1 on: June 06, 2006 - 01:13:21 AM »
I have seen them on Ebay.
Current Vehicles:
Plymouth PPR Cuda 1970 489 cid
Plymouth GTX 1970 RS23V0E
Sorry my bad english...I'm just an european...
Offline miketyler
    • www.miketyler.net
« Reply #2 on: June 14, 2006 - 05:36:44 AM »
Yup - Ebay or I think Aloha Automotive may have some
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline ShelbyDogg
« Reply #3 on: June 15, 2006 - 09:35:41 AM »
I have 2 of those with a complete overhead wiring harness from an SE I parted out in '85.  What are those worth?  I've seen low fuel lights in other old Mopars and I think they are driven by the same choke device.
Offline miketyler
    • www.miketyler.net
« Reply #4 on: June 19, 2006 - 07:44:55 PM »
Dealers were pricing used units to me for ~$30ea or so.
If you are the adventureous type you may want to try one from a later optioned 72 model Imperail or other car. NOS units can still be found and are dirt cheap. They are smaller than the 70-71 units. I was told they could work as replacement. I would have to look but I think the original had 4 leads and the later model had three. It was explained to me that one of the ground leads was omitted in the later model.
LMK if you want a part number - in fact I ended up buying a complete setup from Aloha so I never tried it. You can have it if I can find it  :biggrin: :eek7: :biggrin:
72' Cuda restomod
70 Mustang Mach 1
« Reply #5 on: June 19, 2006 - 08:59:45 PM »
You need to install a PVC for street use.
