Author Topic: MSD ignition  (Read 783 times)
Offline Sublime1970
MSD ignition
« on: June 05, 2006 - 11:40:36 PM »
I'm wiring my challenger for a msd and the key power must be wired to a acessory power, one that does not cut out when starting the car, any ideas so far all acessory powered wires i have put a test light on cut out when starting.  Any help would be awesome.
Re: MSD ignition
« Reply #1 on: June 06, 2006 - 12:23:17 AM »
Dk Blue is the run wire & Brown is the start wire , both go to the ballast resister , you will need to tie both togehter & hook them to the MSD trigger wire
 Don`t ask how I know right Kelly  :banghead:
Offline Sublime1970
Re: MSD ignition
« Reply #2 on: June 06, 2006 - 07:17:25 PM »
Sweet I have been testing everything and it has been driving my up a wall, thanks man now i can hook that up and get this monster running!
Jon
Offline wart1de
    • Vivah
Re: MSD ignition
« Reply #3 on: June 06, 2006 - 07:52:21 PM »
I had a stupid mechanic connect a negative wire to the position terminal on the coil.. He didn't tell me and thought he was fixing something because the wire was sitting there loose.. Next time I go to start the car the MSD6AL has smoke pouring out of it. grr
1973 Plymouth 'Cuda
1980 Ford Falcon XD ESP
2012 Jeep Wrangler Rubicon
Re: MSD ignition
« Reply #4 on: June 06, 2006 - 11:56:36 PM »
I havee seen a bunch of MSD s go up in smoke & not for any good reason most of the time
Offline Sublime1970
Re: MSD ignition
« Reply #5 on: June 08, 2006 - 08:47:00 PM »
Thanks for the info i hooked it up last nite like you said and it worked like a charm.  She fired right up, thanks again!
