Author Topic: choke wire position  (Read 623 times)
Offline MoparMatt383
  • Member as of March 2004
choke wire position
« on: June 05, 2006 - 11:41:25 PM »
I have an edelbrock performer carb with the electric choke on my 340 in my 73 barracuda.  Just wondering where do you guys have your choke hot wire ran to.  Right now I have mine hooked up to the coil, which I know is wrong but its just temporary till I get the new motor tuned right.  Any thoughts?
Matt
Too many projects and nothing gets done.
Re: choke wire position
« Reply #1 on: June 06, 2006 - 12:24:17 AM »
the dark blue wire thaat goes to the ballast resister is the wire you need to tap into for 12v switched power
Offline Mopar73340
« Reply #2 on: June 06, 2006 - 03:58:53 PM »
Being that your car is a 73, there should already be a blue wire running along the passenger side valve cover that should have a female connector on it that stops in the original choke area to feed the original choke. It has the 12 volts you need also.
« Reply #3 on: June 07, 2006 - 03:05:31 PM »
Ok I know the wire that you are talking about.   :thumbsup:
Matt
