Author Topic: 71 Cuda Brake Proportioning Valve Rebuild?  (Read 2851 times)
Offline Total BS
  • '71 Carrabuda Baby!
« on: June 06, 2006 - 10:02:50 PM »
Hi C-C gang,
I got a call from the resto shop today.  They are reinstalling my brake system and they feel that the proportioning valve may not be working properly as they are only getting fluid to one wheel. As I am a technical dummy, can anyone tell me if these can be rebuilt and possibly by whom. I am trying to keep this resto as authentic as possible and would like to reuse this if possible without having to switch to one of the other non-correct valves that some of the brake line vendors sell. If you have done it please enlighten me.  Attached is a pic of my setup before teardown.  Thanks, Ed
PS, my car is a 383 AT with power brakes, front disc brakes, rear drums
« Last Edit: June 06, 2006 - 10:19:22 PM by Total BS »
1971 'Cuda 383
1970 Chevelle SS LS6
1999 Durango
-New Joisey-
Re: 71 Cuda Brake Proportioning Valve Rebuild?
« Reply #1 on: June 07, 2006 - 12:14:28 AM »
the large nut can be remove to access the inner parts , I my attitude is if a human can build it I can rebuild it + you have nothin got lose if it doesn`t work you are still in the same bind
Offline Total BS
« Reply #2 on: June 07, 2006 - 09:03:05 AM »
Chryco,
Thanks.  I found this picture of an exploded view of the valve from a 69 RR.  It looks to me that all there really is is a couple of O-rings and maybe the springs that could be replaced. I think I might give it a shot.
1971 'Cuda 383
1999 Durango
-New Joisey-
« Reply #3 on: June 08, 2006 - 02:15:01 AM »
Why not !
Offline Grancoupe
« Reply #4 on: June 08, 2006 - 09:22:31 AM »
While I was reading this one thing can to mind. You are talking about the front brakes, correct?. The rear brakes have only one line going to the rear. If this concerned the rear it would not have anything to do with the proportioning valve. Only asking
« Reply #5 on: June 08, 2006 - 01:28:35 PM »
the proportioning valve balances pressure between the front & rear brakes
Offline Grancoupe
« Reply #6 on: June 08, 2006 - 01:58:29 PM »
Doesn't it act as a splitter from left to right as well?
Offline Total BS
« Reply #7 on: June 08, 2006 - 11:56:10 PM »
I am going to take a guess and say that the metering block next to the proportioning valve splits the left and right on the front brakes. I don't have my car here to verify it so it is just a wild guess
1971 'Cuda 383
1999 Durango
-New Joisey-
« Reply #8 on: June 09, 2006 - 02:12:38 AM »
no , it has to have equal pressure to the left & right & it does Tee it so it goes to both but it is wide open to each side
Offline Grancoupe
« Reply #9 on: June 09, 2006 - 09:44:08 AM »
Cool, Been a while since I touched one of the old systems.
