Author Topic: freeze plugs...  (Read 821 times)
Offline TreeFrog
    • TreeFrog
freeze plugs...
« on: June 08, 2006 - 12:30:23 PM »
any suggestions on putting freeze plugs in a 340 while it is still in the Challenger?
apears i blew two out this past winter, both on the Pass side. :working:
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
Offline cjm
  • 70 Cuda - In Progress.....
Re: freeze plugs...
« Reply #1 on: June 08, 2006 - 04:06:19 PM »
I did it on a 70 cuda with a 340. I had to disconnect the passenger side header. There is also a plug behind the motor mount. If you need to access that one (I didn't), you would need to remove the mount. You could lift the engine with a hoist, just enough to remove the mount without removing the engine. Again, I did this on a 70 Cuda, I assume that it is the same for a Challenger.....
Note: When installing you could use a socket close to the size of the plug. It will make it go in more evenly when tapping it in.........
