A roots blower is a positive displacement supercharger. That means for every rotation of the rotor, a certain amount of air is carried in. Those have immediate boost, at any rpm. The faster it spins, the more boost it has "right now". A centrifical supercharger has a boost curve, similar to a turbo. Thats why the compressors look similar to each other. That means, a big centrifical also has "lag". The Shelbys are great cars. If you drove an automatic, you really felt lag. If you drove the stick, and could drive it well, the boost was very fast for the time. The VNT shelbys were outstanding even with the automatics. But, for the displacement, the turbo was big..The exh side was sized too big. A V8 will not have that issue, and in fact, most turbo manufacturers now are beter at sizing things up and matching the exh size to the application. A 302GMC (stovebolt) 6 cyl I know of has a compressor size 2.5 times the size of a Buick 3.8L Grand National, but with the small exh side, the boost is instantaneous, and it produces 25lbs of boost at full boogie. If you drive a 5.0L Mustang with a P1SC, you'll notice the boost really comes on at about 2500rpm, because of the small cubes. A roots style blower on the same engine has full boost right off idle.
