Author Topic: shifter rebuild  (Read 1321 times)
Offline pink panther
shifter rebuild
« on: June 12, 2006 - 11:31:18 AM »
Well it happened again Sunday, the car stuck between 2 gears. The shifter needs to be rebuilt and I called Hurst they will rebuild 5-10 days for $90.00  pluss shipping.  Anyone have any feedback with their work or turnaround time?  Think since it is so close to Carlisle I will have to yank it out of there and send it in for repair after we get back. seems to only get hung up when at a stop and shifting gears, shift while still rolling works fine.  Going to try and see if re-allinging helps, but I think the shifter is worn.
Any thoughts? can these only be rebuilt? can you buy new?
Offline matt63
Re: shifter rebuild
« Reply #1 on: June 12, 2006 - 07:33:38 PM »
The first place I would go is Brewers.  I believe they have rebuilt units.  Hurst does not make a shifter specifically for the E body (wrong levers) anymore.
Matt in Edmonton
'68 Valiant
Re: shifter rebuild
« Reply #2 on: June 13, 2006 - 09:56:27 AM »
Matt,
do you have a web adress for brewers?
Re: shifter rebuild
« Reply #3 on: June 13, 2006 - 05:01:21 PM »
probably just cleaning & rebuilding it yourself will make a big difference , I can send a spare shifter for parts if needed  , you could also buy a new comp + shifter & use your levers
« Last Edit: July 20, 2006 - 11:33:57 PM by Chryco Psycho »
Offline matt63
Re: shifter rebuild
« Reply #4 on: June 13, 2006 - 05:21:43 PM »
Here is the Brewers address http://www.brewersperformance.com/
The guy there told me that the E body shifters have different leves (inside the shifter) than the B body units.  I don't see why you can't make a B body shifter work though.
Matt in Edmonton
'68 Valiant
Re: shifter rebuild
« Reply #5 on: July 20, 2006 - 07:06:59 PM »
OK, now that we are back from Carlisle I'm pulling the shifter out and sending it to Hurst for rebuild, feels sloppy and I have adjusted the linkage.  An Old Mopar mechanic in my car club verified the shifter is worn.  Question is: do I need the installation kit also after it is rebuilt?  Need to send it soon so it will be back and in the car for Monster Mopar in Sept.
Re: shifter rebuild
« Reply #6 on: July 20, 2006 - 11:34:40 PM »
you shoul;d not need the install kit
Re: shifter rebuild
« Reply #7 on: July 21, 2006 - 07:27:51 AM »
TY Chryco, if I knew how to rebuild it myself I would have taken you up on your offer of parts.
Re: shifter rebuild
« Reply #8 on: July 21, 2006 - 10:42:32 AM »
If I had more itme I would have rebuilt at Carlisle
Re: shifter rebuild
« Reply #9 on: July 21, 2006 - 06:09:23 PM »
yeah, you were pretty busy. appreciate you trying to help though.
