Author Topic: You can tell if a car has power brakes by looking at engine bay, right?  (Read 2727 times)
Offline Grec
The brake booster on this Challenger looks different than other ones that I have seen on known PB cars.
This is most likely standard, non-power drum brakes, no?
« Last Edit: June 12, 2006 - 09:07:47 PM by Rev-It-Up »
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Offline FM3V6M
  • TX9 383 4spd
    • mytx9cuda
You have manual drum brakes...there would be a booster otherwise.
Offline moparnut
    • My Photo's
Dont you love the way Chrysler would throw a BB at drum brakes?I have them on my GC as well,not for long.
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
Offline Grec
Thanks, guys.
- 440 Six Pack
Offline Steve P.
Could be non-power DISC brakes. You need to look behind the front wheels to tell. Definately not power though..
Offline Carlwalski
Is that an odd setup with no power brakes yet A/C?  :clueless: :dunno:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline R/T
  • Johnson City TN
My 73 challenger has non power disc brakes . It looks exactly as that one in the picture above.
1973 Challenger (OO/=====\OO)  440
Hemis and Harleys
2008 Dodge Ram Big Horn Edition  5.7 Hemi
Offline JH27N0B
They did have non power disc brakes available on Ebodys, but not in 1970. I think the non power DB option started in '71 or '72.
The engine compartment shot shows a drum brake style master cylinder.  The disc brake one has one fluid chamber that is about 3X the volume of the second fluid chamber.  Also the lid is held on by a bail wire.  The drum brake master cylinders through 1970 had a bolt on filler cap.
It's a strange set-up for sure. I have 73-76 A-body disc brakes on the front of my car. Manual to boot. I once had AC, but my master cylinder looks nothing like that. I really don't think that is Mopar. I think it might be an after-market master cylinder.  :dunno: Unless it is from some 80's Mopar, then that I wouldn't know about.  :-\
« Last Edit: July 04, 2006 - 02:26:29 PM by MEKrunner »
Offline R/T
  • Johnson City TN
You are correct, I went and looked and mine has the wire bail that holds the cap on.
Hemis and Harleys
