Author Topic: Tailight buckets  (Read 1575 times)
Offline Tropicalcats
  • Don't Ever, Ever Give Up
Tailight buckets
« on: June 13, 2006 - 01:55:50 PM »
What is the best way to clean up the tailight buckets as well as the ones for the side markers. Do the get a coat of paint ? if so what color? or just cleaned up?
« Last Edit: June 13, 2006 - 02:03:16 PM by Rev-It-Up »
SOLD
Offline Mopar73340
Re: Tailight buckets
« Reply #1 on: June 13, 2006 - 03:22:31 PM »
I glass bead blasted mine and then used some reflective paint although I think they were plain from the factory.
« Last Edit: June 14, 2006 - 01:55:11 PM by Mopar73340 »
Offline basement
« Reply #2 on: June 14, 2006 - 07:58:06 AM »
All I did was soap and water them. Then finished off the trunk and the back of the tailight buckets with a textured trunk paint. It may not be original but looks great.
Offline Killer_Mopar
« Reply #3 on: June 14, 2006 - 12:07:03 PM »
I cleaned and scuffed my set down and finished them off with a coat of duplicolor aluminum paint. I have a picture somewhere, when I find it I will scan and upload it......
« Reply #4 on: June 14, 2006 - 02:37:37 PM »
Thanks guys I would appreciate any pictures. I want to stay as original as possible.
SOLD
« Reply #5 on: June 15, 2006 - 12:06:00 AM »
If you want to keep them as original as possible then just clean them up and put them back on. Here is a picture of my buckets with the aluminum paint....although it isnt original, I feel that it finishes the trunk better than the factory finish.
« Reply #6 on: June 15, 2006 - 06:51:30 AM »
those look great Killer.
I'm thinking that might be the way to go.
SOLD
Offline fishn4cuda
  • Cuda Fan!
  • Ft. Jennings, OH
« Reply #7 on: June 15, 2006 - 10:54:26 AM »
You could also try some stainless steel paint in an arosol can. It will have a closer grey appearance. Then clear it with Diamond crystal clear (from eastwood).
Cant kill the mean and ugly. Only the good die young...I plan to be here a while!!
« Reply #8 on: June 15, 2006 - 11:41:51 AM »
Thanks guys some great ideas.
Anybody know how to get the wire out of the front side bucket
SOLD
Offline Mt.St.BigBlock
« Reply #9 on: June 16, 2006 - 12:18:54 PM »
I'm fairly certain that comes out of the housing as an assembly with the lamp
socket. Gently pry between the housing and the socket outer ring.  Jeff
71 cuda 383 3spd manual gy9
