Author Topic: Caked on Mud hardened over 10 years of sit'n  (Read 1707 times)
Offline JimCuda
  • MOPAR > Move Over Plymouth Approaching Rapidly
« on: June 13, 2006 - 07:06:27 PM »
 :1zhelp:
Anyone have any good ideas on removing 10 years of hardened mud on the under belly of a car? This stuff is like concrete.
Any spray on solvent that will break down the mud that is there?
Offline wart1de
    • Vivah
Re: Caked on Mud hardened over 10 years of sit'n
« Reply #1 on: June 16, 2006 - 03:13:58 AM »
I would've thought some high pressure water would have got it off.
Maybe it is cement?  :lol:
1973 Plymouth 'Cuda
1980 Ford Falcon XD ESP
2012 Jeep Wrangler Rubicon
Offline 360 'CUDA
« Reply #2 on: June 16, 2006 - 10:25:18 AM »
I had that on the bottom of my truck... I'm thinking some high pressure steam on that?
Offline TreeFrog
    • TreeFrog
« Reply #3 on: June 16, 2006 - 11:19:57 AM »
hmmer screwdriver, chisle, etc.
when you are not knocking it off, keep it wet, and it may help
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
Offline dougs bs23
« Reply #4 on: June 20, 2006 - 10:47:05 AM »
get your safety glasses  and a hammer and tap it from the edges to the center to kind of crack it loose,, then either a power washer or a steam genny. Good luck,, have fun  dont get dirty :roflsmiley:
« Reply #5 on: June 20, 2006 - 11:56:47 AM »
IF it is just dried mud get it wet & after a little while a pressure washer should knock it of easily, but what you may have is a buildup of road grime/tar/concrete etc. which may need a little acid to break up. I discoved that some citrus cleaners do a pretty good job of loosening hardened STUFF.
« Last Edit: June 20, 2006 - 01:09:05 PM by bullitt99 »
Offline JimCuda
« Reply #6 on: June 20, 2006 - 06:41:44 PM »
Thanks for the advise guys. I haven't tried much in the form of a power washer because the car doesn't currently run. I have tried some can spray items without much luck so i think I will take your advise. I will try to push the car outside and getting a power washer on it.
Offline bordin34
« Reply #7 on: June 23, 2006 - 07:47:37 PM »
Are you sure its not undercoat?
1973 Charger SE Brougham Black 400 auto
1974 Charger SE Brougham Blue 318 auto-SOLD
Offline JimCuda
« Reply #8 on: June 23, 2006 - 08:11:03 PM »
Nope, it was about 10 pounds of caked up beach/clay sand.
I pushed it out of the garage this week, jacked it up and washout the under belly to get it wet. I later came back and hit it with 2400 PSI pressure washer w/ the zero tip (this will take off paint if you leave it there long enough), which did the trick. Matter of fact in some areas the under coating was coming off showing the lemon twist under it when I spent too much time removing the dirt.
I can now see the starter and a host of other nuts and bolts!  :bananasmi
