Author Topic: 72-74 Cuda front bumper fit?  (Read 3108 times)
Offline miketyler
    • www.miketyler.net
« on: June 13, 2006 - 07:31:55 PM »
I am putting my front bumper back on now and it doesnt seem to fit too well. Its a refurb bumper from Keystone and looks ok but it looks to make a different angle than the grille. Anyone got pics of the topside of their bumper line relative to the grille?  I am about tempted to pull a Chip Foose here and either reform or cut the bomper in the center so it matches the grille better. Shouldn't it align with the lower grille lip better?
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline JimCuda
  • MOPAR > Move Over Plymouth Approaching Rapidly
Re: 72-74 Cuda front bumper fit?
« Reply #1 on: June 13, 2006 - 07:49:45 PM »
Got any before pictures with the old bumper?
Offline Ravage
  • 1974 318 'Cuda
« Reply #2 on: June 13, 2006 - 07:51:32 PM »
Hot off the presses
"I flipped off a box of kittens once..." (Tycho on being evil)
Offline miketyler
    • www.miketyler.net
« Reply #3 on: June 13, 2006 - 08:00:31 PM »
No, I cant find any pics that have good shot of the mating lines of the grille and bumper.  Ravage - thanks for posting the pics but I cant really tell for sure at the ends how much of a gap if any there is. Does your bumper aligh perfectly with the grille? It looks like it might from the pics
« Last Edit: June 13, 2006 - 08:15:32 PM by miketyler »
72' Cuda restomod
70 Mustang Mach 1
Offline Ravage
  • 1974 318 'Cuda
« Reply #4 on: June 13, 2006 - 08:02:54 PM »
sorry the pics aint better ,cheap camera and tight garage.Yes the angles are perfectly parallel.Yours looks to be rather far off it seems  :(
« Last Edit: June 13, 2006 - 08:05:34 PM by Ravage »
Offline JimCuda
« Reply #5 on: June 13, 2006 - 09:14:48 PM »
I see what you mean. The lines of the old bumper used to go right along the lines of the grill, where the new one leaves more of a gap as you progress out to the lights/fenders.
I'm not sure if I would cut and re-fit maybe minor heat and bend (Not sure if the chrome would discolor though?
Does Keystone accept returns, maybe try yearone? Anyone else have a Keystone bumper and have pictures of the fit?
Offline miketyler
    • www.miketyler.net
« Reply #6 on: June 14, 2006 - 10:48:16 AM »
this bumper was on the car when I bought it; I may try and reform it, I can't believe that I have the grille tweeked in at a different angle than it should be.
Also, how much space is there supposed to be between the bumper and the grille? My 72 didnt have a filler strip. I thought it looked better if it was closer in and more "snugged up" to the grille and fenders
« Last Edit: June 14, 2006 - 12:04:05 PM by miketyler »
72' Cuda restomod
70 Mustang Mach 1
KTO
« Reply #7 on: June 14, 2006 - 11:44:33 AM »
Here is a link to what I did on the 73...
http://www.cuda-challenger.com/cc/index.php?topic=15725.msg160310#msg160310
I agree...the bumper line is a touch off. The center is closer to the grill than the outer portions.
It doesn't look as noticable once you tuck the bumper though.
Offline miketyler
    • www.miketyler.net
« Reply #8 on: June 14, 2006 - 12:14:26 PM »
I pulled the bumper brackets last night and slotted the holes to allow the bumper to come in closer - your illustrations are spot on there.
In additon to slotting the holes, I am going to try and put a little more V in the bumper. Any ideas on how I might accomplish this?
72' Cuda restomod
70 Mustang Mach 1
KTO
« Reply #9 on: June 14, 2006 - 12:22:20 PM »
I would have tried changing the angle a bit if I was at the point where my bumper still needed chroming or paint. no luck for me there.
I cant think of a great way to make the angle sharper off hand... You could put it in a hydraulic press and get more angle... however, I'd be worried about wrinkling the top of the bumper...If the bumper still needs rechroming that wouldn't be too much of a problem, you could hammer and grind the wrinkle down before chroming. Just a thought.... I am a hack though :)
Offline miketyler
    • www.miketyler.net
« Reply #10 on: June 15, 2006 - 05:00:25 AM »
Well I gave it a shot, the bumper looks to be a fresh rechrome from Keystone. I succeeded in clsoing the V but did wave the top flange. I striaghtened it with no damage to the chrome. I pulled all the brackets off and if I can snug it in close enough, it will look pretty good except for the end 2-3 inches.
I intend to do all my brackets like you had done, I think it will look slick. Similar to chromed version of the fiberglass bumper
72' Cuda restomod
70 Mustang Mach 1
Offline Ravage
  • 1974 318 'Cuda
« Reply #11 on: June 15, 2006 - 06:10:53 PM »
glad it worked out ,w00t   :thumbsup:
Offline miketyler
    • www.miketyler.net
« Reply #12 on: June 17, 2006 - 08:05:48 PM »
It turned out to be more of a challenge than just lengthening the slotted holes. On the drivers side outboard bracket, I found that I had to slot the hole past the break in the angle to get the bumper snugged in where I wanted it. This was all good until you torqued it down. When the bolt was tightened it would draw the end of the bracket inboard. I tried a clipped washer and considered a tapered shim to alleviate the condition but in the end I cut the bracket, removed 1/2" section and rewelded it. I know it seems kind've extreme but I piddled around with it for 2 hours before I said screw it and got out the welder.
72' Cuda restomod
70 Mustang Mach 1
Offline Ravage
  • 1974 318 'Cuda
« Reply #13 on: June 17, 2006 - 08:08:11 PM »
A lot of screwing around but it was worth it ,looked a bit silly with that angle before.Nice work  :thumbsup:
Offline 73EStroker
« Reply #14 on: June 20, 2006 - 09:49:25 PM »
A tip - always send your old part in to get redone if it is still in good shape. Don't go with the exchange pieces.
Barry (Salmon Arm)
