you can rotate the engine until the valve is 6* before TDc for the exhaust valve or 6* Adtc for the intake valve & depress the valve & measure the clearance with a dial guage
having said that I have never seen a valve come to close to a piston with .520 lift or less
my choice would still be the Engle cam & I have used a lot of them , the Voodoo is close but just slightly milder , either will work well
