Author Topic: New 340 Cam...Just can't decide?????  (Read 2640 times)
Re: New 340 Cam...Just can't decide?????
« Reply #15 on: June 20, 2006 - 10:16:30 AM »
I would say the number one reason would be a cam lobe not shaped correctly when the cam was made. The lobes are not "flat" they are made with a slight taper to them so one side of the bottom of the lifter gets contacted first make the lifter rotate .
 Exactly , the lobe is not flat except at the top , the ramps are tapered to contact 1 side of the lifter so it has to rotate , if it doesnt rotate the cam is not shaped correctly
Offline woody9512
  • 71 Billboard Cuda, Pistol Grip 4-speed.
« Reply #16 on: June 20, 2006 - 11:30:59 AM »
Chryco...or anyone else who has used the Engle Cams.....K 56...or K58 that I'm thinking about using.........Since I have power brakes on my 340 Cuda will either of these cams have enough vacuum to still run my power brakes??? Just wonder if they have been installed with power brakes and what the end result was??
"Woody"
Offline tactransman
« Reply #17 on: June 20, 2006 - 11:37:30 AM »
I have a 292 duration  .501 lift cam on my 360 and the power brakes sucked! I did put a vacuum can on it and it helped alot. I would say they are worth adding on, so if you would have any booster issues you could always add one. :2cents:
Terry-tactransman
Union, Mo.
Offline woody9512
« Reply #18 on: June 20, 2006 - 12:54:53 PM »
If at all possible I would like to just stick to my stock booster..just wonder if anyone currently has one of the Engle cams and what the result was?
"Tim"
Offline tactransman
« Reply #19 on: June 20, 2006 - 01:09:26 PM »
Yea , they kind of defeat the purpose if you are wanting to keep your engine compartment
 " uncluttered"
Terry-tactransman
Union, Mo.
« Reply #20 on: June 21, 2006 - 12:46:24 AM »
I used a K58 in at least two power brake car with no problems
Offline rallyechall
« Reply #21 on: July 14, 2006 - 07:23:58 AM »
One thing you will want to do is broach the lifter bores. This will ensure they are the correct diameter for the .904 lifters.  You may find that the 1 and 2 lifters were tight in the bore. You can get the broach from the link below.
http://www.hughesengines.com/partDetail.asp?partID=10096&eTypeID=20
