Author Topic: 73 Cuda Factory Air Shock Option?  (Read 988 times)
Offline 73_Cuda_4_Me
« on: June 15, 2006 - 05:26:36 PM »
Was there a factory-installed rear air shock option on the 73 Cuda...???
My rear valence actually has 'flats' formed into the lower portion of the valence, about 1 inch in from bottom front lip, and centered just inside the exhaust cutouts, and the separate air valves/tubing to each shock are mounted in those formed flat areas. There are little plastic push-in tubing holders located around each side, up frame rail and up to top of shock.
I'll try to get a shot or two showing the setup.
Any info would be greatly appreciated! Thanks in advance!
73C4Me
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
Offline inot2old
Re: 73 Cuda Factory Air Shock Option?
« Reply #1 on: June 15, 2006 - 07:12:02 PM »
No e bodies came with air shocks.  I have a '73 Cuda and a '70 Challenger and both have air shocks with the valves located in about the same place.  The cuda, it is behind the license plate and the Chally it is in the trunk in about the same area.
My Cuda valance also has the area that you describe, but I just have empty holes there.
'71 Cuda
'70 Charger project
'05 Crossfire Roadster
Offline 360 'CUDA
« Reply #2 on: June 16, 2006 - 10:31:19 AM »
But by 1976 all E-bodies had them...  Most Camareos and Ferberds too    :roflsmiley:
