Author Topic: Viper front brakes and rear disc  (Read 1153 times)
Offline BA340challenger
« on: June 16, 2006 - 04:53:12 AM »
I recently picked up a set of 1996 viper gts calipers. I also am going to get SSBC rear disc conversion. My questions is what Master Cylinder are you guys using when you have 4 wheel disc brakes. Also I know I need a propotioning valve, but is anything else needed?
Thanks
Offline MyMopar
Re: Viper front brakes and rear disc
« Reply #1 on: June 27, 2006 - 02:12:35 PM »
You know I was just reading on eof my off-road mags and in the new products section it had a company that made a proportioning valve that could be used with disc/drums, disc/disc, drum/drum they said you name this ONE valve will do the trick.  Problem is I haven't been able to locate that mag since I saw that ad.  MIght want to do a search on google for off-road proportioning valve, Jeep conversion proportioning valve or something like that.  If I find it I'll post it up.
1969 (OO===]|[===OO)
1973 (OO/=====\OO) <---SOLD
1997 (O|||||O) <---SOLD
Smoke tires, not drugs!
Offline Hopalong
  • HEAD OFF! Apply directly to the neck line!
« Reply #2 on: June 27, 2006 - 08:31:23 PM »
Have you tried talking to SSBC about this.  They probably have the right master cylinder and propotioning valve for you.
{oo/===\oo}
