Author Topic: Timing  (Read 686 times)
Offline basement
Timing
« on: June 16, 2006 - 08:00:27 AM »
Hello
I've been fiddling with the timing on a stock 360 and don't know if I'm making things better or worse. Whenever I use the timing marks on the dampener and a light the motor won't even idle if I get even close to tdc. Right now the mark is way past after tdc. So, I've just set the timing so the engine idles smooth at an idle rpm. Chryco, I read somewhere that you suggested running the rpms upto 3grand and adjusting the distributer until the rpms start to drop off. Do I have this right? Tonight I want to check and make sure the rotor is for sure pointing directly to no.1 cylinder at tdc of the compression stroke :undercar:, maybe that's why I can't use a light.
Offline basement
Re: Timing
« Reply #1 on: June 16, 2006 - 08:04:20 AM »
Think I found the answer. Started searching previous messages on 'timing' and found some usefull info on timing by ear.
Re: Timing
« Reply #2 on: June 16, 2006 - 09:58:05 AM »
let me know if you still have problems
