Author Topic: w-2 heads???  (Read 5200 times)
Offline moparnut
    • My Photo's
w-2 heads???
« on: June 17, 2006 - 09:10:52 AM »
Which car came with w-2 heads?Some ta's had 202 J heads,why would they have to different sets of heads?
thanks
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
Offline tactransman
Re: w-2 heads???
« Reply #1 on: June 17, 2006 - 09:55:17 AM »
I do not know of any cars that came with W-2 heads from the factory.(it has been awhile though since I have been into the engine stuff, it's all trannies now) The heads do have off set rockers but I do not think they are " W-2"
 "W-2" are a Direct Connection (Mopar) racing cylinder head.
« Last Edit: June 17, 2006 - 12:01:33 PM by tactransman »
Terry-tactransman
Union, Mo.
Offline moparnut
    • My Photo's
Re: w-2 heads???
« Reply #2 on: June 17, 2006 - 10:23:56 AM »
Thanks I always wondered that :cheers:
Re: w-2 heads???
« Reply #3 on: June 17, 2006 - 09:18:38 PM »
the W2 used the same offset rockers as the TA heads BUT the W2 was never used in production , it was considered for the LIl Red Express trucks but dropped to make things more confusing the w2 is offered in a # of different versions & can be very expensive to get set up with special rockers , pedestals Etc
Offline moparnut
    • My Photo's
Re: w-2 heads???
« Reply #4 on: June 17, 2006 - 11:02:14 PM »
Thanks Chryco,but my TA heads dont have offset rockers,look like to me the regular shaft mounted rockers as usual on most mopar sb heads.Are mine not Ta?The casting numbers say they are,I am just trying to learn more as usual :bigsmile:
Re: w-2 heads???
« Reply #5 on: June 17, 2006 - 11:53:48 PM »
both the J casting & T/A J casting had the 915 part # the pushrod holes are clearly moved away from the intake port on the true T/A heads this requires special rockers for the intake , the rockers are shaft mounted either way but the pushrod will hit the intake port wall if you use normal LA engine rocker arms
Offline moparnut
    • My Photo's
Re: w-2 heads???
« Reply #6 on: June 18, 2006 - 11:02:40 PM »
Boy CHryco,you just saved me from yet another blunder,lol,i probably would have put regular rockers on.If i post a pic tomarrow can you tell me if they are the TA heads?thanks
Re: w-2 heads???
« Reply #7 on: June 18, 2006 - 11:38:45 PM »
yes If you take a clear pic of the pushrod hole in the head
Offline moparnut
    • My Photo's
Re: w-2 heads???
« Reply #8 on: June 19, 2006 - 11:54:48 AM »
Thank You Chryco,here are the pics
« Last Edit: June 19, 2006 - 01:47:29 PM by Rev-It-Up »
Re: w-2 heads???
« Reply #9 on: June 19, 2006 - 12:17:39 PM »
those are the regular 915 heads , not T/A heads though , sorry
Offline moparnut
    • My Photo's
Re: w-2 heads???
« Reply #10 on: June 19, 2006 - 01:09:56 PM »
Thanks,wonder why the casting number says they are? :dunno:
Offline moparnut
    • My Photo's
Re: w-2 heads???
« Reply #11 on: June 19, 2006 - 01:20:09 PM »
Chryco,this was posted on a set of J heads a while ago on ebay.I was just wondering how much of this is true?The flow comparrison chart I negleted to save.
Mopar Small-Block HP J-Casting Cylinder Heads!
Maximum factory power for your small block... at NO RESERVE!
Just clearing out parts left over from a stroker project that ended up going a little wilder than planned (meaning W2 heads)... what's being auctioned here is a pair of the famous 1970-71-only 340 head castings.  Casting number on these heads is 3418915, but they're commonly known as "J" heads.
This pair of castings was factory-machined for 2.02" intake valves... a trick used only in 1970-71.  Casting dates on these heads are 2330 (August 21, 1970) and 2510 (September 8, 1970).  These are REAL 340 heads--notice that where the "360" designation is normally cast, the 6 is missing, leaving only "3 0".  Real 2.02" J-heads are the only heads so cast.  These are the heads so desired for performance use.  The intake-port flow is virtually tied with the famous 894-casting 340 "X" head, but their exhaust ports outflow any other factory LA casting (see flow chart below).  These are an excellent upgrade for your small-block performance project.
These heads will really wake up virtually any small-block, though 273s require a bore notch to clear the 2.02" valves (and 318s benefit greatly from the same process).  These are a great swap for early 360s and small-valve 340s.  I bought these heads as a complete set, and as such, they had valves, springs, etc.  The springs were a little tired, so I dumped them--but I had the valves cleaned up and checked.  The intake valves are all in excellent shape (I wouldn't hesitate to use them) and the exhausts are usable but I'd probably replace them.  I will include the valve-spring retainers but some of the locks were cracked (you should always buy new anyhow)
Both head castings have been beadblasted and magnafluxed, and neither head is cracked or damaged in any way--all threads are good, no marring or warping was found.  Of course, they sat more than 5 minutes, so they started to rust a little, but it will bead-blast right off.  There is typical pitting between the center exhaust ports on both heads--but it doesn't cause leaks or any other problems.  The valve seats are fine --just lap 'em and you're done, though for unleaded use, you'll probably want to have hardened exhaust seats installed.
Your heads are the key power-makers for your small-block Mopar... why screw around with inferior heads from a 318 or 273, or even the mediocre "587" or "345" casting 360 heads, when a pair of good "J" heads is still affordable?
Thinking about those fancy Edelbrock heads?  Keep in mind that all else being equal, aluminum makes less power due to heat loss... and no, the weight difference doesn't make up for the power loss (it's that much).  Simple engineering principles at work.
Also, Edelbrock heads can't be ported any further than either X or J heads, because it has the same limitations (factory-style valvetrain) as the OEM castings!  The Edelbrock design is nothing more than a slightly-port-matched J head, cast in aluminum.
So, if the flow is the same and the power is less, why waste the money?
Re: w-2 heads???
« Reply #12 on: June 20, 2006 - 12:25:45 AM »
while everyhting he says is basically true , the X&J heads are about equal & have always been known as the best heads to get & the comparison to the Eddys is also basically correct as well I bet he didn`t flow the 308 castyings against the J heads , I have personally seen over 40 HP gain going from x & J castings to ported 308 castings with no other changes
Offline moparnut
    • My Photo's
Re: w-2 heads???
« Reply #13 on: June 20, 2006 - 09:08:24 AM »
thanks Chryco,I'm always learning.......................................
