Hey everyone. Been a while since I posted, got a new job, having a baby, and just getting back into my 73 Challenger street project.
Last week I got a complete 5.9L Magnum and a518 transmission out of a 96 ram truck. The price on it was so low I juts snatched it up.
The good:
Ive got pretty much everything: engine harness, transmission harness, computer, engine bay harness. The guy even threw in the dash and dash harness. Im not too worried about the condition of the engine, it turns by hand and has decent compression.
The Bad:
This is my first time with efi, and the amount of wiring is daunting. Theres a handfull of loose connectors. The overdrive unit needs more room under the tunnel to fit under the car. The original slapstik transmission linkage won't fit. I just learned my original driveshaft will not only have to be shortened by about 3.5" but the yoke will need to be replaced as well. The throttle lever is on the passenger side, so I need to reconcile that.
What I know I need: New transmission crossmember modded ~2" lower than stock ( I think I can handle this)
A good driveshaft shop.
High pressure external fuel pump, regulator, pre and post pump filters, return lines.
New shifter linkage, or modify the original...
Exhaust system. I wanted to go with a tti system, but if Cat's are absolutely required, what else is out there? Can I put is a dual exhaust with only one O2 sensor? (maybe Im missing an O2 sensor?)
I know someone's done this before (on a 73 Cuda??) I would love to know how the install went, what was kept and what was tossed.
Are there any other resources out there for this kind of swap?
Im not scared of the swap so much as I am intimidated by the wiring....
Thanks!
