Fuel pump, dist and carb selection
Author Topic: Fuel pump, dist and carb selection  (Read 1181 times)
Offline MoparMatt383
  • Member as of March 2004
« on: June 19, 2006 - 06:18:49 PM »
Just was wondering about fuel pump, dist, and carb selection on my 340 and if what I have is adaquate.  Its a 340 with KB pistons, edelbrock performer rpm cam, performer rpm air gap intake, mildly ported 915 J heads, about 9.5 to 1 compression and hooker super comp headers.  The carb I have is an edelbrock performer 600, a new stock fuel pump, and a new stock distributor.  These were all parts that were on my 318 for a short time.  Any thoughts?
Matt
Too many projects and nothing gets done.
Re: Fuel pump, dist and carb selection
« Reply #1 on: June 20, 2006 - 12:31:40 AM »
if the dist is a Mopar electronic it will be fine , you may want to shorten the timing curve or just unplug the vacuum advnace & increase the initial timing
depending how you drive the 340 the carb is probably too small , I like a 700 minimum on a 340
the fuel pump should easily keep up , you could install a high Volume mechanical pump if it seems to lay down at high rpm
« Reply #2 on: June 20, 2006 - 08:19:24 AM »
The dist is an electronic one rebuilt to stock specs.  Its not a Mopar Performance one.  As for the carb being too small would that effect how it ran at idle and just regular driving, not hard acceleration?
Matt
« Reply #3 on: June 20, 2006 - 10:14:23 AM »
the smaller carb will not affect idle or lower RPM driving
Offline todd383
  • I'm a llama!
« Reply #4 on: June 21, 2006 - 08:56:10 PM »
the carb is way too smaLL, you will feel it on the upper rpm's,    and i would definitly go with a better fuel pump.
« Reply #5 on: June 22, 2006 - 10:03:22 AM »
If I do feel it at high RPMs what size fuel pump and carb do you reccomend.  A 750 Edelbrock?
Offline moper
« Reply #6 on: June 22, 2006 - 11:02:29 AM »
Before you upgrade the carb, spend some quality time with the ignition. The stock advances are not conducive to high performance. They are too slow in coming in, and advance too far to keep the power levels where you want them. I would at minimum get the MP light spring pgk, and a timing tape. Install one light in place of the one stiff one in the dist already. The next step, you need to see on the plate the weights slide in (this has to be removed to acces the springs anyway...). It will be stamped with the number of degrees advance it provides. If it's more than 15° then it will need to be welded up. The idea is, if it's stamped "22", you will want to block off the outside 1/3 of each slot. (22-15=7, so you weld up the outer 1/3, and now it's a 15° plate) You need to make sure the slots are filed smooth, so there are no burrs, and you'll want to be sure the center of the pin on each weight contacts the welded spot correctly. So the amoutnyou block out is really only 1/3 of the slot's travel. Then, reassemble the dist., and reinstall it. Set the initial timing to 18°, and the total should now be 33° and it shoudl come all "in" by 3K rpm, leaving the fvaccum advance disconnected, and the line plugged at the carb. Then, plug the line back on the vaccum pod. Most have an allen wrench accessable adjustment screw inside the nipple where the vaccum line plugs on. You can either add or remove preload on the diaphram to quicken or delay the pod's advancing. Counter clockwise adds preload (delays the pod) and clockwise removes preload (quickens the application of the vaccum pod). Popping or surging means you need to delay it a little more. I start with that adjument set for quickest application (no preload), and test drive. If it pops when floored,  go 2 turns of the wrench, then test drive again. No pop but a light throttle surge, at cruise, add another 2 turns. When the surge is gone, it's done. When that's done, you can tell if the carb is too small. My guess is, it wont feel as sluggish, and it might be ok. If I were building this engine, and your rear gears are lower (numerically higher) then 3.23s, I'd run a larger carb. The 750 Thunder AVS would be my first choice.
