Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
dana slipping
« previous
next »
Print
Pages: [
1
Author
Topic: dana slipping (Read 1134 times)
70challengerrt
Jr. Member
dana slipping
on:
June 19, 2006 - 06:42:26 PM »
Today I got cocky since everybody helped out and the motor has no more vibrations so I decided to do a burn out and had a nice set of lines for about 15 feet then I felt the car shift and it when to a single tire.
Is there any thing a guy can add to get the clutches to work for the summer? This winter I will replace or rebuild it. Is a dana cone or clutch pak set up?
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: dana slipping
Reply #1 on:
June 20, 2006 - 12:18:24 AM »
Dana is a clutch type
try changing oil in the diff for now
Logged
Challenger6pak
Resident
Re: dana slipping
Reply #2 on:
June 20, 2006 - 06:57:13 AM »
There is a small bottle of additive that Chrysler sells for limited slip differentials that makes the clutches grab better. You may be able to get an equivalent at a parts house.
Logged
70challengerrt
Jr. Member
Re: dana slipping
Reply #3 on:
June 21, 2006 - 05:07:46 PM »
I changed gear lube and put in lucus and it holding for now. Thanks
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: dana slipping
Reply #4 on:
June 22, 2006 - 02:59:19 AM »
the additive is a friction modifier , it actually makes the fluid More slippery to stop the clutches from grabbing
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
dana slipping
