340-4bbl to 340ci-SIXPAK in the 'Cuda - Help
Author Topic: 340-4bbl to 340ci-SIXPAK in the 'Cuda - Help  (Read 2935 times)
Offline Carlwalski
« on: June 20, 2006 - 04:27:43 AM »
I've decided the 4bbl is too sucky, in terms that it feels almost too "wild". You really have to feather the throttle to get it warmed up nicely getting some good air and fuel up, it's a decent sized carb and IMO too big for my "daily" driving wants. It does need a tune and will be drivable but I've decided I want to get a 340-6bbl setup. The looks are a little better but not my main concern, will my performance increase or decrease? The Demon carb on at the moment is a double pumper 800cmf (I think?).
My 340ci (70-74 block) engine specs: (from previous owners paper work/receipts)
Estimated hp is around 350-360hp at the fly wheel.
Cylinder Heads:
 - Factory W2 oval port intakes
 - D-Port exhaust
 - Extensive port
 - bowl and combustion chamber mods
 - Hardened exhaust valve seat inserts
 - Ferrea 2.02 intakes
 - 1.6 exhausts
 - Comp-cam 995-16
 - Valve springs 1.70" installed height, 130lbs at the seat
 - Comp cams 740-16 10 degree retainers & 10 degree valve locks
 - Crane roller rockers 1.5 ratio
 - Offset intake rockers, straight exhaust rockers
 - 450 340 STEEL CRANK
 - Penned rods
 - intake and headers all port matched
 - High volume sump and oil pump.
Camshaft:
 Comp cams 20-224-4 extreme energy, 110 degree lobe centers, .488" intake valve lift, .491" exhaust valve lift, 230 degree duration @ .50" intake, 236 degree duration @ .50" exhaust. RPM operation range 1800-6000rpm. Comp cams custom length pushrods, comp cams hydraulic lifters. jr double row steel timing gear set.
Transmission:
TorqueFlite-727, 2800rpm stall 3:23 8-3/4" Suregrip
Who sells the most complete kit for the best price and the best quality?
Will my engine setup do a 6bbl justice or am I better off sticking to a big 4bbl?
Is this set up/crowd any good?
http://cgi.ebay.com/ebaymotors/New-OEM-Mopar-340-6-PACK-6BBL-COMPLETE-Carbs-Intake-PKG_W0QQcmdZViewItemQQcategoryZ34198QQitemZ4652020067QQrdZ1QQsspagenameZWDVW
Thanks in advanced.
Cheers,
Carl
NZ440R/T
« Last Edit: June 20, 2006 - 04:36:56 AM by NZ440R/T »
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline 1BADFISH™
Re: 340-4bbl to 340ci-SIXPAK in the 'Cuda - Help
« Reply #1 on: June 20, 2006 - 09:17:21 AM »
Hey Carl, I hear a lot of good things about Six Pack Performance in New Mexico.
Here's the number: 1-(505)-345-8539
Charlottetown, PE
2014 GMC Sierra Crew Cab White Diamond edition.
1970 Dodge Challenger 340-6 4spd.
*Member Since* Oct 11, 2005
Offline Carlwalski
« Reply #2 on: June 20, 2006 - 09:28:49 AM »
Hey Dave, all good brother I found the website a while ago, did some research and have sent some emails.
I only really call if I have to as 10 minutes can cost $30.  :eek7: ;)
 :cheers:
Offline 1BADFISH™
« Reply #3 on: June 20, 2006 - 09:31:21 AM »
 :cheers:
Thats some expensive airtime, you should look into Skype, 20 cents/min or something for the internet phone and it works good, I use it for overseas calls.
Charlottetown, PE
Offline Carlwalski
« Reply #4 on: June 20, 2006 - 09:40:06 AM »
Thanks Dave. My Uncle works for them and is making some "top secret device" worth 10's of millions+.
No shlt, I swear. He's been in Japan, US with big company bosses getting backing and funds to put it into market.
I know who I'm being real nice to in my greater family.  :naughty: :lol:
Offline 1BADFISH™
« Reply #5 on: June 20, 2006 - 09:48:26 AM »
Cool, keep me posted when it comes out. I may have to invest. Or buy stocks if you give me a little notice before the big release...lol.   :bigsmile:
Charlottetown, PE
Offline Carlwalski
« Reply #6 on: June 20, 2006 - 09:52:06 AM »
I won't know basically until the public. He's only told my Mum being the brains of their 7 siblings and being a top accountant. Helping him out with money issues etc.
My own Mum won't even tell me.  :pullinghair:
Though, for good reason, when I get drunk I'll probably tell 37% of New Zealand. lol  :roflsmiley: :drunk: :lol:
Anyhow, back to business.....4bbl vs 6bbl and-the-like.  :biggrin:
Offline Robb
« Reply #7 on: June 20, 2006 - 10:03:59 AM »
Who did APril get her 6-Pack from ?   She seemed REALLY pleased with the process and outcome.
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
« Reply #8 on: June 20, 2006 - 10:31:39 AM »
That is the place April got her system from & yes they are great to deal with
 Now the bad news ... there is no intake available for the W2 heads to my knowledge
Offline Robb
« Reply #9 on: June 20, 2006 - 11:23:49 AM »
Which heads do you recommend NZ get for the 6pack Chrycho ?
what about a better cam ?
Offline Carlwalski
« Reply #10 on: June 20, 2006 - 06:48:52 PM »
Man, that sucks!?  :crying: I thought I read somewhere that T/A's-AAR's came with W2-heads?  :dunno: :-[
If I tuned the carb I'm sure performance would be equal to or greater than 6bbl?
Maybe I can get a 4bbl 6pk baseplate/air cleaner. I'll have the look and performance.
That big ar$e Demon surrrre is purtty.  :grinyes:
Thanks for the good and bad news, but I won't be changing the heads, too much money and work involved and I've been told they're really good heads to have, not cheap too.
 :walkaway:
« Reply #11 on: June 21, 2006 - 12:57:20 AM »
LET me see if I have this right ................what heads would I recommend to replace a $3000 set of real good heads so he can spned $3000 on a 6 pack which will not make one more HP than he has now  HMMMM I would say go with the edelbrock heads if you are going to be that dumb they will cost you another $1500 & lose more power too
 no stay with the heads & carb you have , sounds like some serious $$ was spent to do this engine right the first time
« Last Edit: June 21, 2006 - 12:59:16 AM by Chryco Psycho »
Offline Carlwalski
« Reply #12 on: June 21, 2006 - 01:23:51 AM »
Thanks Chryco, that's what I'm thinking too. He has spent big dollars on the engine, head work mainly.
I think I'll get the Demon tuned properly and keep that as-is.
Is there anywhere that makes the 4bbl 6bbl set up so it looks like a "6bbl" but the base-plate houses a 4bbl carb.
:dunno:
« Reply #13 on: June 21, 2006 - 02:42:51 AM »
1badfish just sold a 6 pack air cleaner the fit a 4 bbl carb , they are reproduced so no prob getting one
Offline Carlwalski
« Reply #14 on: June 21, 2006 - 03:00:55 AM »
Thanks, do you know who sell a complete 4bbl kit? Shakerhood.com?
Do you have any links or places who sell it? I can't find any at the moment via Google.  :dunno:
