Author Topic: Mounting specs for a trunk spoiler  (Read 5327 times)
Offline tactransman
« on: June 20, 2006 - 02:43:21 PM »
Does anyone have a template or correct measurements for mounting a trunk spoiler?
Terry-tactransman
Union, Mo.
Re: Mounting specs for a trunk spoiler
« Reply #1 on: June 20, 2006 - 03:15:07 PM »
Sorry I don't. Believe it or not, I just eye-balled mine. You can get a pretty good feel if you have moved it back too far. It was REALLY scary drilling those holes in the trunk lid though.  :22yikes:  :22yikes:  :22yikes:  For what it's worth, my spoiler is now matte black(came to my senses).
Offline Ravage
  • 1974 318 'Cuda
« Reply #2 on: June 20, 2006 - 07:37:37 PM »
I also eyeballed mine to roughly match what everyone else was doing ,about 1 cigarette pack length from the edge to the post on a 'cuda  :bigsmile: Certainly is scary putting that first hole in ,but by the time you get to the 4th one it's not so bad ,and by the 8th you hardly notice you were off by half an inch the first time  :banghead: measure once cut twice or something like that.
"I cut this piece 3 times and it's still too short"
"I flipped off a box of kittens once..." (Tycho on being evil)
Offline 70challengerrt
« Reply #3 on: June 20, 2006 - 08:01:47 PM »
I installed the brackets first and then drilled the holes which is basicaly marked the other side to match.
Offline Carlwalski
« Reply #4 on: June 20, 2006 - 08:19:01 PM »
Do the (FPAP) First Place Atuo Products wings not come with mounting instructions?  :dunno:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline Challenger6pak
« Reply #5 on: June 20, 2006 - 08:46:37 PM »
The factory 70 & 71 trunk lids have the holes partially cut out on the backside.  What year E are you mounting it on?
Offline Desmo
« Reply #6 on: June 20, 2006 - 09:54:04 PM »
The Year One instructions are something like:
1. Using a ruler, center the wing on the trunk lid. Use masking tape to protect the finish, and (I would assume) also to allow you to make marks - without touching your paint. I'd stripe the rear area with tape here just in case.
2. Measure from the bottom edge of the trunk lid, forward 8 1/2 inches (following the contour of the trunk lid) - to locate your rear mounting hole location. You now have an x and y axis. One point is the result for each leg.
3. Use the spoiler legs as a guide to find the forward mounting hole location.
4. Drill four 5/16 inch mounting holes (through the masking tape to reduce the potential for paint chipping). Smiling all the time... :bigsmile:
5. Test fit the spoiler. Release held breath.
6. Install the spoiler mounting brackets, to the spoiler studs on the trunk underside use them to find the places to drill for your under lid brackets attachment holes (assuming your trunk is not original or NOS, in which case those holes are already there).
7. Bolt it all up...tight but not Arnold tight!
HOPE THAT HELPS!  :2cents:
Offline EVIL72
« Reply #7 on: June 21, 2006 - 06:02:22 AM »
  Is it just me or does the Challenger wing look like it sits too far forward?
 Has any of the non factory wing guys/girls ever tried to place the wing farther back on the trunk lid on there Challenger? Not hanging out past the trunk, just more like how the Cudas wing sits?
 Maybe not actually drill any holes, but just seeing if it still fit, and if so, did it look better? Is there still enough support etc?
ROB
1972 Dodge Challenger 340ci
1970 Pro Street Duster (Under Construction)
« Reply #8 on: June 21, 2006 - 06:50:23 AM »
My picture is a little deceiving. It makes it look like it's more forward than it is. I'll try to get a better shot later. In answer to your question, if you go too far back with it, then the pedestals won't be sitting on a flat part of the hood. I'm not sure if I'm painting a clear picrure here, but you don't want to mount the pedestals on the part of the lid that starts to curve downward.
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
« Reply #9 on: June 21, 2006 - 06:54:22 AM »
Welcome to the board Desmo and thanks for the info! :grinyes:
Offline Carlwalski
« Reply #10 on: June 21, 2006 - 07:58:21 AM »
As MEK said it looks deceiving, like casting a rod into the ocean.  ;)
Here's a Go-Wing on a 'Cuda rear, MEK's looks pretty spot on to me.  :cheers:
« Last Edit: June 21, 2006 - 08:00:42 AM by NZ440R/T »
« Reply #11 on: June 21, 2006 - 09:35:57 AM »
Spoiler mounting holes.
Offline tactransman
« Reply #12 on: June 21, 2006 - 09:51:52 AM »
Thanks Guys, This is going to go on a friends '73 rallye and this car has been totally redone so I wanted to make sure it is installed OEM. He is getting the correct(OEM equivalent) spoiler. I have been trying to get him to join the forum but he does not do computers much. I will get some pics when we get it all installed. His car is very nice! :cheers:
Terry-tactransman
Union, Mo.
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #13 on: June 21, 2006 - 09:59:07 AM »
Here's a pic from the Year One catalog that one of our members sent to me.  Hope it's helpful.
« Last Edit: June 23, 2006 - 12:08:44 PM by Rev-It-Up »
« Reply #14 on: June 21, 2006 - 03:57:38 PM »
For what it's worth, I took some measurements of mine today. 7 inches up from the trunk lip was as far back as I could go.
