Author Topic: I.D.'ing Course vs. Corse Spline Yoke  (Read 2080 times)
Offline 70 Cuda 340
« on: June 20, 2006 - 04:51:30 PM »
Are there any EXTERNAL indicators on the yoke to tell me if I have a fine (29) or course (10) spline drive pinion in a '70 489 rear-end? It's a long sorted story, but the short version is I want to order a new ring and pinion for my 489 rear, but don't know if I need a fine or course set-up. Someone is doing the work for me and I'd like to have the right part on hand when I drop the car vs. having the car sit in the shop waiting for a part to arrive.
Any clues?
Re: I.D.'ing Course vs. Corse Spline Yoke
« Reply #1 on: June 20, 2006 - 05:03:10 PM »
Hello,
  And welcome aboard here.  :wave: You have asked a good question. I have a 70 with a 489, but unfortunately, I can't help you. Great question though. I'm sure someone will be along shortly to help you.
Offline tactransman
« Reply #2 on: June 20, 2006 - 05:18:08 PM »
The only way I know to tell is to take the pinion nut off and look at the splines . You can tell without taking the yoke off. If you are getting it rebuilt any way , zip the nut off and look at it and then tighten it back up.Unless it is an older pumpkin it will most likely be 29 spline. :cheers:
« Last Edit: June 20, 2006 - 05:20:05 PM by tactransman »
Terry-tactransman
Union, Mo.
« Reply #3 on: June 21, 2006 - 12:42:38 AM »
where are the measurements  :banghead:
 10 spline has asmaller nut , I think 1 1/4 , 29 spine is 1 5/16
Offline 70 Cuda 340
« Reply #4 on: June 21, 2006 - 10:04:56 AM »
Hey Chryco, are you saying the pinion nut size is in fact an external indicator that can be relied upon, i.e. 10 spline  1 1/4 , 29 spine 1 5/16?
Offline tactransman
« Reply #5 on: June 21, 2006 - 10:13:11 AM »
I wouldn't trust the nut size because I had a guy do a rear end for me along time ago and he needed a different nut for the after market gears and he found one in his "goody" drawer .He could not tell me what it was off of. :eek7:
Terry-tactransman
Union, Mo.
« Reply #6 on: June 21, 2006 - 10:16:17 AM »
yup , the nut size isd different
Offline 70 Cuda 340
« Reply #7 on: June 21, 2006 - 11:23:55 AM »
Pardon my ignorance, by I haven't spent much time outside the engine comparment on this, or any other mopar for that matter. Is the nut we're referring to accessible on the outside of the case without having to dismantle anything? (I'm hoping you say yes :))
Thanks again for your help.
Dan
Offline tactransman
« Reply #8 on: June 21, 2006 - 05:00:34 PM »
It is the one that holds the yoke on the pinion shaft.(in the middle of the rear end yoke)
Terry-tactransman
Union, Mo.
« Reply #9 on: June 22, 2006 - 02:57:49 AM »
you will have to unbolt the driveshaft  , I found the nut , the 10 spline is 1 1/8 " , the 29 spline must be 1 1/4 or bigger
Offline tactransman
« Reply #10 on: June 22, 2006 - 01:12:12 PM »
 Duh , you mean the tread size of the nut. I thought you were talking about the socket size. :banghead:
Terry-tactransman
Union, Mo.
« Reply #11 on: June 22, 2006 - 01:45:46 PM »
yes the socket size
 , 10 spline is smaller at 1 1/8 "
