Author Topic: 727 re build info needed  (Read 1311 times)
Offline 70 rtse
« on: June 21, 2006 - 04:54:51 AM »
Going to get a rebuild on my 727 i wanted to put a stage 2 shift kit in it but the guy said that it should have a mopar shift kit in it as it is a r/t car.What should i ask for in the re build to make the trans stronger. :feedback:
Offline tactransman
Re: 727 re build info needed
« Reply #1 on: June 21, 2006 - 06:29:12 AM »
The stage 2 is fine. If you are talking about internal mods to make it stronger I would say a billet aluminum rear servo piston , make sure your intermediate lever is a 3.8, kevlar bands front and rear and throttle pressure( kickdown) adjusted right. :thumbsup:
« Last Edit: June 21, 2006 - 06:36:35 AM by tactransman »
Terry-tactransman
Union, Mo.
Offline wssnkc
  • Go Mango R/T 440 4bbl
« Reply #2 on: June 21, 2006 - 06:36:14 AM »
With regard to suggestions on what makes the 727 trans stronger, ck out the following:http://www.transmissioncenter.net/727Transmission.htm although I didn't use them for my rebuild cause they were discovered after-the-fact. If I ever need to again I will likely contact them the next time. Speaking of the next time, I have no idea when that might be as a bone stock 727 is, in my opinion, the strongest (factory-built) auto trans ever made. However, some have said, first-gear burnouts have been known to do damage to stock 727's.
Lots of people like Turbo Action's Cheetah valve body #17676 which has the benefit of a standard shift pattern.
« Last Edit: June 21, 2006 - 06:41:37 AM by wssnkc »
Offline 70 rtse
« Reply #3 on: June 22, 2006 - 07:43:12 AM »
Thanks for the info any one know what he means by the mopar shift kit.
Offline tactransman
« Reply #4 on: June 22, 2006 - 07:49:19 AM »
The Mopar shift kits that I have seen are not worth messing with . Overpriced for sure.
Terry-tactransman
Union, Mo.
Offline 70 rtse
« Reply #5 on: June 22, 2006 - 07:53:35 AM »
He said that if you put a stage 2 in it that i will have truble whith it better to keep it stock is the mopar shift kit stock what is your sugestions
Offline tactransman
« Reply #6 on: June 22, 2006 - 07:58:36 AM »
It sounds like he does not know what he is doing. Does he have a good reputation and is he experienced in Torqueflites? Does he do this for a living (9 to 5) or does he do it "side job" wise in the evenings?
Terry-tactransman
Union, Mo.
