Author Topic: Somewhat urgent: passenger door will not open, latch won't budge  (Read 6333 times)
Offline wiging19
Re: Somewhat urgent: passenger door will not open, latch won't budge
« Reply #15 on: July 03, 2006 - 11:27:06 AM »
Thanks.  I'll take the door panel off and see if it is in the bottom of the door.  Some how I don't think that part will be there because I had the car repaint last fall and I think my body man would have put that part back in place.  I'll let you know if the part is there.  Thanks for the feedback on that problem.
:violin:
Offline BE-Body
  • Newbie
« Reply #16 on: January 21, 2021 - 04:56:47 PM »
I have a 1970 'Cuda C7, 383 with an automatic trans.
My problem was the same as Sukhoi's,- my passenger's door would not open.
When I looked inside with a pen light everything was working and moving as it should. This lead me to believe that the outer latch was not moving on the post to allow the door to open as it should.
I took a spray can of WD40 placing the nozzle to where I thought that the latch was and sprayed away and luckily it worked.
So I just wanted to say "THANK YOU" to all who answered this older post.
