Author Topic: 340ci 4bbl Air Grabber Setup?  (Read 1076 times)
Offline Carlwalski
« on: June 21, 2006 - 08:34:11 AM »
OK, the 6bbl is not for me, intake won't work with my heads and as I thought I will be making better power as is so why spend $3K+ to gain nothing, perhaps even a bit slower? Anyhow, my decision has been made now I need some more help.
I want to get a Air grabber to fit over my 4bbl. I know 69? 383ci grabbers sit higher on the baseplate and won't clear the hood, so I will be looking for a 69 440 air grabber setup, correct? Will it cover/fit a 800-850cmf Demon double pumper carb, they aren't the smallest carbs in the world.  :sly:
My main questions:
1) Will a 4bbl 440 68/69(?) air grabber setup fit my Demon & sit under the Cuda bulge hood without mods?
2) Where can I find a complete setup? (If at all possible)
3) What else do I need to know/buy? Or is it simply buy the setup, install drive.
4) Will the air grabber get enough air in compared to a stock airfilter? Is it actually worth it, gains or decrease?
Like the ones below is what I am after.
Thanks in advance.
Cheers,
Carl
« Last Edit: June 21, 2006 - 08:38:43 AM by NZ440R/T »
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Re: 340ci 4bbl Air Grabber Setup?
« Reply #1 on: June 21, 2006 - 10:21:38 AM »
I have no idea if that will fit as the intake height maybe way to high to fit it under hood , orginal aic cleaners are over $500 if you can find one but the repro ones are easy to get & far Cheaper , 440 units were much more rare too than 383
 all you need is the base & lid & filter , it will fit a Demon , it has a standard mount
Offline EvilTwinATX
« Reply #2 on: June 21, 2006 - 10:54:36 AM »
Try this guy... his name is Steven Matthews. He owns Hybrid Fiberglass Solutions (http://www.hybrid-fiberglass-solutions.com) and is very knowledgeable. and his prices are reasonable! He makes all his own stuff and I have talked to him several times... he is a good guy. I even think he is making some baseplates for people with clearance problems. (I dont remember the exact details.)
Anyway, I was going to order a 4bbl adapter baseplate from him - but I decided to put a shaker on my car instead.. :woohoo:
He should be able to hook you up! Tell him Brent from Austin sent ya'...
Offline Carlwalski
« Reply #3 on: June 21, 2006 - 11:15:14 AM »
Thanks CP & Brent, I have sent an email off to hybrid-fiberglass. Great site with some nice products. They look like what I am needing. I sent him hood photos, engine and specs and if he needs more photos I'll send them.
Thanks guys. Chryco, my engine has a highrise manifold, not sure what type, Mopar Performance I know that much.
Maybe you can see from the photo if it will fit or not? If not, no drama.  :thumbsup:
 :cheers:
Offline Robb
« Reply #4 on: June 21, 2006 - 11:34:24 AM »
On the demon carb I had (and gladly got rid of),
the choke rod likes to interfere with the lip of the hole of the aircleaner.  It is different in than a holley in that regard as it is further "outboard" than a holley.  Choke sticks and doesnt want to open all the way on the dual snorkles
watch out for that.
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
« Reply #5 on: June 22, 2006 - 03:05:33 AM »
it should fit But Steven at Hybrid will know better what will fit
