Author Topic: Parts for Fuel injection  (Read 688 times)
Offline BA340challenger
« on: June 22, 2006 - 11:32:54 AM »
I have been reading articles about Megasquirt EFI. I am very interested but I do not have a lot of knowledge with EFI. If I wanted to set my 340 up with MPI what parts would I need. Please help.
I have a victor 340 manifold how much would it cost to get it machined and welded for fuel rails? Who have you guys used?
Where do I get fuel rails?
What size injectors? 450-475 horse +100 shot of nitrous.
What is a good cheap throttle body and where can I get it.
Any other information is greatly appreciated.
THANKS!!!!
Re: Parts for Fuel injection
« Reply #1 on: June 22, 2006 - 11:42:54 AM »
Holley has fuel rails availble in diffrent lengths , you just need to drill it in the locations where th einjectors luine up , something in the 45lb / hr range should fit your needs Mega squirt can help with the exact size you will need , you will need a high flow fuel pump too
 there are throttle bodys available from a # of suppliers ranging in price from $500 - 1200
« Reply #2 on: June 22, 2006 - 11:47:52 AM »
Who would you recommend to weld bungs onto the manifold? Also when drilling fuel rails do you drill all the way thru to the center or counterbore them?
Thanks
« Reply #3 on: June 22, 2006 - 11:51:03 AM »
usually just bore deep enough to seal the O ring & leave a ridge ijnside to stop the injector going into the tube & blocking the flow to other injectors
depending what bungs are used they can be threaded or epozyed into the manifold , anyone with a Tig welder could weld them in for you
Offline ShelbyDogg
« Reply #4 on: June 23, 2006 - 06:34:29 AM »
Here's the other thread with a link to a guy I use.  $175 to drill an weld bungs. He also supplies rails.
http://www.cuda-challenger.com/cc/index.php?topic=22150.0
If you want a quick, working complete fuel injection kit, get the Edelbrock.  They put alot of money into R&D and never ever sell a bad product.
