From what I have found, the change over is easy. The top part of the belt mounts in an existing hole shown earlier in this post. The interior panel is the same. It has been cut out and a bezel is added that screws into the seatbelt retractor. A reinforcement is added below quarter window crank so that the belt assembly does not move back and forth. This can be made out of 1/8th inch. plate. The bottom bolt goes through the floor and is attached by a nut. The floor does not appear to be reinforced. The other half of the belts bolt in next to the console as always. I do not know if you can use the 70 female ends. You may only be able to use 74 ends. I am checking that one. I will take measurements before I finish parting this car. Let me know if you need them.
