Author Topic: SOME TIMES IT DOES SOME TIMES IT  (Read 1791 times)
Offline justin16440
« on: June 24, 2006 - 03:19:23 PM »
Broke in my new motor the other day everything went fine. today I turn the key and nothing. I can jump the relay and it will start but not with the key. Wire harness is new, starter relay is new sanded under the relay with no success. Went outside and tried it again and it worked shut it off and it would`nt start with the key again. any sugession
Offline Hemi Challenger
  • Nothing run better then a HEMI
Re: SOME TIMES IT DOES SOME TIMES IT
« Reply #1 on: June 24, 2006 - 03:29:11 PM »
Sound like a Faulty Relay to me , Good Luck
« Reply #2 on: June 24, 2006 - 04:22:19 PM »
A bad ignition switch?  :dunno:
Alaskan_TA
« Reply #3 on: June 24, 2006 - 04:24:38 PM »
Check the wiring harness plugs for the column too, look for corrosion, clean it as needed and make sure it goes back together tightly.
Best of luck,
Barry
« Reply #4 on: June 24, 2006 - 06:36:48 PM »
How about the neutral safety switch that provides a ground to the solenoid on an automatic. or the clutch safety switch does the same on a straight shift? Several folks here have had that issue. I think it is the brown wire w/yellow stripe.
« Reply #5 on: June 25, 2006 - 12:42:11 AM »
I would start there too
Offline Rob C
« Reply #6 on: June 25, 2006 - 12:54:16 AM »
I have the same dang problem in my '79 Magnum with the starter realay jumped out to skip over the neutral saftey switch.
I think I'm down to the keyed switch or like said above, the contacts on the column. UUURRRGGGG!!!!
'73 Cuda, 360, 4psd & 4.10's
'79 Dodge Magnum, 360, 727, 9-1/4 W/3.55's
Offline justin16440
« Reply #7 on: June 25, 2006 - 08:31:15 AM »
Cleaned all the terminals and still nothing I have the starter relay grounded under my wiper motor I think I will change that and see if that will do anything.
Offline Grancoupe
« Reply #8 on: June 25, 2006 - 09:12:20 AM »
Your going to need to start tracing for power and work your way forward until you find where it gets cut off.
Offline justin16440
« Reply #9 on: June 25, 2006 - 05:09:19 PM »
Brown wire on the ballast was loose  everything is fine. :banghead: feeling kinda stupid
« Reply #10 on: June 25, 2006 - 07:52:11 PM »
I'm glad to hear problem solved,  :clapping: what I don't understand is I thought it would not crank. I tought ballast only had to do with getting power to the ingition system.  :clueless:
« Last Edit: June 25, 2006 - 07:53:52 PM by bullitt99 »
