Author Topic: Glass Codes  (Read 782 times)
Offline Challenger6pak
Glass Codes
« on: June 24, 2006 - 08:41:34 PM »
Does anyone have or know where I can get a chart for the PPG codes on glass?  I have many extra pieces of glass I would like to identify the date codes on.  Thanks for your help.
Offline RusTy/SE
  • Just havin' fun
Re: Glass Codes
« Reply #1 on: June 24, 2006 - 10:35:34 PM »
  The last set of numbers under "PPG" will represent the date code on your glass. For instance where "X9",  'X' can be one (1) thru nine (9) to indicate the month of manufacture and the number '9' will indicate the year 1969. If the last set is "XX9", then 'XX' will indicate ten (10) thru twelve (12) for the month with '9' once again indicating 1969.
Russ
« Last Edit: June 24, 2006 - 10:57:06 PM by RusTy/SE »
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Re: Glass Codes
« Reply #2 on: June 25, 2006 - 07:23:27 PM »
Thanks Russ.
Offline RusTy/SE
  • Just havin' fun
Re: Glass Codes
« Reply #3 on: June 26, 2006 - 07:09:53 AM »
You're welcome :cheers:
Russ
2001 Durango     1B4HS
