Author Topic: Vibrating or rattling noise?????  (Read 4794 times)
Offline JRoss22
  • Member Since 05/08/2005
« on: June 25, 2006 - 11:12:20 PM »
 :pullinghair: Ok so ever since I put my gas tank back in my car dont know if this is related to it or not, When ever I am driving the car and I have the throttle pushed down it sounds like either the drive shaft is vibrating or the transmission is. I can try to record the sound next time I have the car out and am driving it but I amd wondering what could be making the sound. It is coming from closer to the firewall from what I can hear so maybe it could be something with the engine. Anyone :dunno: :clueless:
Re: Vibrating or rattling noise?????
« Reply #1 on: June 26, 2006 - 01:46:25 AM »
too many possibilities , could be wheels or driveshaft out of balance & possibly a bad trans mount or about 100 other things
Offline JRoss22
« Reply #2 on: June 26, 2006 - 01:47:16 AM »
I was afraid it would be to hard to pin point.... :pullinghair: :pullinghair:
Offline Carlwalski
« Reply #3 on: June 26, 2006 - 01:49:57 AM »
Any other way you can describe it Ross?  :dunno: :clueless:
As Chryco said there could be many different possibilities.
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline JRoss22
« Reply #4 on: June 26, 2006 - 02:05:09 AM »
I just confered with my dad as I pointed it out to him while I let him drive my car today. He says he thinks its something with the valves i think he called it a valve tappet or something like that from using cheap gas. :dunno:.. But back to the sound now that I think of it the sound has more of a knocking noise to it.. Its just all so confusing maybe I will take the car out again first thing in the morning when I wake up to re-think over the sound.
Offline Carlwalski
« Reply #5 on: June 26, 2006 - 02:07:22 AM »
Lifter noise eh.  :pullinghair:
Offline JRoss22
« Reply #6 on: June 26, 2006 - 02:08:50 AM »
Could be that and how would I go about figuring if that is the cause of the noise?
Offline Carlwalski
« Reply #7 on: June 26, 2006 - 02:10:12 AM »
Good question, Chryco will know. For starters you'll need to get into it.
May need some new lifters. Chryco?  :dunno:
Offline JRoss22
« Reply #8 on: June 26, 2006 - 02:12:54 AM »
That is a good question.. And Chryco is just the man to know that answer... Gotta love having his knowledge of these cars :cheers:
« Reply #9 on: June 26, 2006 - 02:13:53 AM »
if it is cheap gas it is pinging , it should happen when you floor at at low RPM , otherwise known as detonation which can distroy an engine
 for the most part lifters are very reliable & will never make a sound unless they will not hold pressure at that point the pushrods will hit the rocker arm possibly bending it plus the valve will not open causing a misfire aswell
« Reply #10 on: June 26, 2006 - 02:15:01 AM »
pinging can be stopped by using better fuel or retarding the timing slightly
Offline JRoss22
« Reply #11 on: June 26, 2006 - 02:16:05 AM »
How would I go about retarding the timing.. Thats all new to me or should I stop using arco gas as price wise its the cheapest out here?
« Reply #12 on: June 26, 2006 - 02:34:15 AM »
to retard the timing you need to loosen the dist & rotate it very slightly [clockwise on a small block & counterclockwise on a big block ]
Offline JRoss22
« Reply #13 on: June 26, 2006 - 02:43:35 AM »
Thanks CP I will try that tomorrow and see if it solves the problem and if it doesnt solve it :pullinghair:.... Well if it doesnt solve it I am going to take the car down to the local resto shop and see if they can help me pin point the problem and solution to it....
Offline 67Vette427
  • My other car is not a Rambler
« Reply #14 on: June 26, 2006 - 09:37:39 AM »
When you retard the timing the engine rpm should decrease. You may need to adjust your idle. Get a timing light too. If you advance it the rpm will increase. You can also throw a can of octane booster in which should counter act the cheap gas quickly.
1 of 1 Mr Norm's T/A/ 2015 Hellcat, sublime/ 13 Power Wagon
