Author Topic: Vibrating or rattling noise?????  (Read 4795 times)
Re: Vibrating or rattling noise?????
« Reply #30 on: July 16, 2006 - 11:49:04 AM »
I think your timing would have to be WAAAY off to cause backfiring. As Goody said, what do your plugs look like. Maybe your carb. is running toooooo lean.
Offline JRoss22
  • Member Since 05/08/2005
« Reply #31 on: July 16, 2006 - 11:50:11 AM »
That could be why I didnt get the choke hooked up... I remember that now because for some reason it just didnt want to hook up properly.... That could deff be my issue thanks for pointing that out....
Offline ShelbyDogg
« Reply #32 on: July 16, 2006 - 10:43:29 PM »
JRoss22,   Backfiring could be caused by the spark plug wires being on the wrong cylinders or a burnt/stuck valve.   Check your firing order first.
Offline JRoss22
« Reply #33 on: July 16, 2006 - 10:45:41 PM »
I know the firing order is correct when I did the tune up on it I had the manual in front of me to make sure I got everything hooked back up properly... I am going to check it out again and maybe pull the valve covers and see if i can find something wrong if not I might just end up tearing down the block for a rebuild....
Offline GoodysGotaCuda
« Reply #34 on: July 16, 2006 - 10:52:51 PM »
In all honesty i've done that myself. i had the book and did it 'correct'. and sure enough there was a issue and i had to go back and i had screwed it up. lol. Takes 2minutes to recheck it, and its not uncommon that you screw it up once or twice in your tinkering/tuning days  :smilielol:
http://www.boxwrench.net/specs/schrys_A.htm
Backfiring would be timing, too lean? that'd lead to pinging, and misfiring/crossed wires.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline JRoss22
« Reply #35 on: July 16, 2006 - 10:57:04 PM »
Thanks Goody for that link saved to my comp and gonna print it up next time I go down stairs to my parents comp to print stuff... And I will double check all the spark plugs and everything when I get the chance
Offline ntstlgl1970
  • T a c o c a t
« Reply #36 on: July 22, 2006 - 08:47:26 PM »
Depending on where you are in Roseville, I would be willing to take a look at it and see if I can help.....
Offline JRoss22
« Reply #37 on: July 22, 2006 - 09:31:08 PM »
I am over by woodcreek. Do you know where that is?
Offline ntstlgl1970
  • T a c o c a t
« Reply #38 on: July 23, 2006 - 12:04:28 AM »
I'm not familiar with woodcreek, but I lived in Citrus Heights for a while, if you can give me some cross streets I'm sure I could figure it out.
