Author Topic: How to test blower motor?  (Read 762 times)
Offline thetex
« on: June 26, 2006 - 07:07:49 PM »
Pulled the cover off to change the heater core and it looks like the blower has not worked in quite a while. Since I have no power because the dash cluster is out can I hook up 12v to the green wire that goes to the motor to test it? I have a feeling it is bad and if it is can you get a reman. from local parts stores?      thanks
Re: How to test blower motor?
« Reply #1 on: June 26, 2006 - 07:12:05 PM »
I think the geen wire is gound, if I recall the power wire is black & connected to the resistor on the heater box. Yes you can test with a 12v battery or battery charger. replacements are common at local parts stores.
