Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
rear main seal leak
« previous
next »
Print
Pages: [
1
Author
Topic: rear main seal leak (Read 1736 times)
70 rtse
Jr. Member
rear main seal leak
on:
June 27, 2006 - 07:20:47 AM »
Can you install a rear main seal whith only the trans out on a 383 motor.
Last Edit: June 27, 2006 - 07:23:18 AM by 70 rtse
Logged
Challenger6pak
Resident
Re: rear main seal leak
Reply #1 on:
June 27, 2006 - 02:02:26 PM »
Yes you can but it is not easy and it does not always work.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #2 on:
June 28, 2006 - 12:39:38 AM »
you will still need to remove the oil pan
Logged
Challenger6pak
Resident
Reply #3 on:
June 28, 2006 - 06:15:47 AM »
Yes, that is true. Just drop the centerlink and wiggle the pan out. I would rather pull the motor and trans to do the seal. Not everyone has the tools to do this so it can be done in the car but might be more difficult.
Logged
70 rtse
Jr. Member
Reply #4 on:
June 28, 2006 - 06:31:02 AM »
Has eny of you done it whith the motor still in the car?
I am getting the transmition re done and would be nise to change the rear main seal while the trans is out as it leaks.
Thank you all for your help
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #5 on:
June 28, 2006 - 10:09:32 AM »
it can be done in car , not fun but possible
Logged
budrinker
Full Member
Reply #6 on:
June 29, 2006 - 07:10:25 PM »
piece of cake ive done it 4 times and looks like im fixin to do it again .......... sigh
Logged
matt63
Sr. Member
Reply #7 on:
June 29, 2006 - 08:38:05 PM »
It's not hard but one of the less desirable jobs that is for sure. Pulling the top half of the seal out can be tricky as can be the installation of the windage tray and gaskets. I would try and use adhesive next time. I have heard of a few tricks to get better sealing. Perhaps CP can validate these. The first is to have 0.010" milled off of the rear main seal cap. The second is to stagger the seal faces so they are not on the parting line. Make sure the seal faces the right direction as it can be installed backwards. Good luck!
Logged
Matt in Edmonton
'68 Valiant
Chryco Psycho
Administrator
C-C.com Guru
Reply #8 on:
June 30, 2006 - 01:17:52 AM »
do as Matt said + put a dab of silicone on the seal ends so they glue together
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
rear main seal leak
