Author Topic: Bumper Guards  (Read 872 times)
Offline Srobinson4
Bumper Guards
« on: June 27, 2006 - 11:24:28 PM »
Will the front and rear bumper guards from a 1972 challenger fit the 1973.  I really dislike the thick rubber of the 73-74
Offline 360 'CUDA
Re: Bumper Guards
« Reply #1 on: June 27, 2006 - 11:55:50 PM »
You want to change to the earlier brackets and bumper or it looks pretty strange
If you just change the guards you end up with weird spaces and extra holes but the early stuff will bolt on
« Last Edit: June 27, 2006 - 11:57:40 PM by 360cuda »
Offline TreeFrog
    • TreeFrog
Re: Bumper Guards
« Reply #2 on: January 05, 2007 - 08:19:07 AM »
will this 72 bumper bolt onto a 73?
are modifications required?
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
Offline TreeFrog
    • TreeFrog
Re: Bumper Guards
« Reply #3 on: January 05, 2007 - 08:25:23 AM »
Think I found some of my answers here.V any other info or advise?
You need both the bumper and the brackets from a 70-72. The 70-72 bracket will not line up with the holes in your bumper (or the reinforcing plate). All the rear bumpers are the same shape and size, but the mounting holes changed on the 73 and 74 ones.
If you want, I guess you could drill your bumper so matches the 70-72 bracket. But then what about the holes from the original bracket? Are you going to paint the bumper? Then you could fill the old holes.
Next problem will be the bumper guards - slots in the rear vallence. You did want to ditch the huge rubber ones right? You will need the 70-72 bumper guards, or fill in the slots in the rear vallence.
To recess the bumpers found on the later model Challengers (e.g. '73 & 74) that have the protruding crash bumpers (the ones that stick out.)  You should will use the 70 & 71  front brackets and 70, 71 & 72 rear bumper brackets.
If it's your intention to remove the large bumperettes found on the '73 and '74 in addition to using the recessed brackets, the front is no big deal since you can remove them and simply replace where it attached with a bumper bolt.  However, the rear is a little more involved and if your are needing more details I will glady share my experiences since I have just made the change on my '73 Challenger.
I agree, I like the way the later year Challengers look using the earlier year bumper brackets.
