Author Topic: 833 OD Tranny Any Pitfalls ???  (Read 3659 times)
Offline Pistol Gripper
« on: May 06, 2003 - 10:59:08 AM »
OK,
I took the Psycho's advice and got me an Overdrive 833.  The guy I got it from told me one of the ears on the side cover had to be upside down.  Question is, are there any modifications I need to make to the shifter/linkage ?  Any other "quirks" ?  Other than that, I'm looking for a better set of gears  ;D  Wonder what the top end will be if I leave the 3.23 gears in it?  Hehe...
O ne
B ig
A $$
M istake
A merica
Re:833 OD Tranny Any Pitfalls ???
« Reply #1 on: May 06, 2003 - 11:49:54 AM »
2 of the three shift rods will adjust , by using the different levers from both trannys you can make the third rod work  you may need to put a slight bend in the rod though.
 you will need to machine down the front brg retainer or swap the one from the tranny you now have as the diameter is slightly larger , 480 to 5.20
 I calculated a theoretical top speed of 225 mph with the OD , 29" tires  & 6500 rpm & 3.54 gears  ;D
« Last Edit: November 04, 2003 - 01:05:39 AM by Chryco Psycho »
Offline cuda
  • 1970 340 Cuda, pistol grip 4 speed,3:91 sure grip
« Reply #2 on: May 06, 2003 - 05:10:35 PM »
I made the swap last year and have never regreted it. Chryco helped with the linkage. The only thing different is the down shift point is a little lower rpm. Or it will grind :o I have 3:91 gears and was at 130 and still had lots left, i was getting a bit nervous ::) Its all good.
Offline BP23N
« Reply #3 on: November 03, 2003 - 08:43:07 PM »
If anyone is wanting one of these 833 OD trannies I am selling one.  I went with the 5 speed keisler and don not need the 833.
« Reply #4 on: November 04, 2003 - 01:08:32 AM »
Welcome BP
 A general Idea where in the world you are located would help a lot !! ;)
« Last Edit: November 04, 2003 - 11:38:45 PM by Chryco Psycho »
Offline BP23N
« Reply #5 on: November 04, 2003 - 06:51:12 PM »
Central Oklahoma. Thanks!
Offline DodgeFreak
  • Cars and trucks are my friends..
« Reply #6 on: November 04, 2003 - 09:55:13 PM »
Price would also help ;D ;D
74 Plymouth Duster- restoring
77 Dodge D150 shortbox- as long as i don't change my mind will be a step side dually diesel or a 383 powered truck
04 durango 4.7
Offline 1973challenger360
« Reply #7 on: November 05, 2003 - 02:28:41 AM »
225mph   try a viper 6 speed with a gear venders 2.76gears 29" tires and a blown destroker at 8000rpms  ;D ???
You know you guys could learn something from Hollywood, when you max out your rpms in final drive, just hit the NOS and you car go another 30-50mph,  Just watch gone in 60 seconds. ::) ::) ::) ::) ::) Got to love Hollywood
« Reply #8 on: November 05, 2003 - 04:27:25 PM »
 ;) Yeah,
  I got the same sickening feeling watching those rice rockets in 2Fast2Furious. Just push a button and bang... I don't think so.
Offline BP23N
« Reply #9 on: November 05, 2003 - 06:48:37 PM »
I will sell the 833 OD for $125.
Offline 360 'CUDA
« Reply #10 on: November 05, 2003 - 09:16:25 PM »
I could use one of those too
How many ya got? ;D
Offline BP23N
« Reply #11 on: November 06, 2003 - 10:43:11 PM »
I have only one if you need it
Offline mikes68charger
  • I'm a llama!
« Reply #12 on: January 05, 2004 - 08:24:16 AM »
So BP23N how much diffrence can you feel after the swap?  Was it worth the Money? Wich trans did you go with? 3550, tko, tkoII ?? Your horsepower?   I would like the 3550 becouse the exstra gear may help me get my larger B body down the road faster. What do you think??
