476 Head porting.
Author Topic: 476 Head porting.  (Read 982 times)
Offline Pistol Gripper
476 Head porting.
« on: June 30, 2006 - 02:46:49 PM »
I have a Porting Template for 3614476 casting "B" heads.  Are they good heads?  Should I look for a set instead of the 906 set I currently have or does someone have a use for the templates ?
P.G.
O ne
B ig
A $$
M istake
A merica
Re: 476 Head porting.
« Reply #1 on: June 30, 2006 - 11:28:00 PM »
I have never seen a 476 casting big block head ,sure thet is the correct # ?
« Reply #2 on: July 01, 2006 - 06:07:38 AM »
CP,
Can't say as I've ever seen one, but they're listed as Stage 4 heads.  And I have the template, it has "B" ENGINE          PORTING TEMPLATES 3614476 CASTING          P 4120437 printed on it. :clueless:
http://www.moparpages.com/tech/articles/tech2.html
They're the 11th ones under big block.
P.G.
O ne
B ig
A $$
M istake
A merica
« Reply #3 on: July 01, 2006 - 08:53:55 PM »
OK, not a production head , the Stage 4 were the early performance heads & the templates would be specific to those heads , if you can find a set the they will definatly be better than the 906
Offline Kapteenikosmos
« Reply #4 on: July 04, 2006 - 10:18:37 AM »
This is from mopar.com, "P4120437   *Porting Template — 2.08/1.74 Valve Size, Cast Iron Head (Big Block Production Heads) ".
As far as I know the template should work for atleast 346,  452 and 902 heads, (mayby 906 and those 476 stage 4 heads too). Templates are only for pocket porting and those should be similar in big block heads?
Atleast I have bought that template too and I intended to use it on my 452 heads. And that porting template is the only one I have ever found on the internet and atleast in that porting article in the moparmusclemagazine they used some commercially available porting templates..
Someone correct if I am wrong.
Ville
1967 six banger Mustang
1973 Challenger (under restoration)
1997 Lincoln Mark VIII LSC (daily driver)
