Author Topic: a/c E-bodys  (Read 3575 times)
Offline todd383
  • I'm a llama!
a/c E-bodys
« on: July 01, 2006 - 04:22:38 PM »
I just purchased  classic air  a/c kit. ( my car has factory air)  what i need is pics, of engine compartments (big blocks) to see were every thing goes, the instrutions that  they give you is from a dodge charger, much different from e-bodys,  can any body help???? thanks
Offline Mopar73340
Re: a/c E-bodys
« Reply #1 on: July 02, 2006 - 09:18:57 AM »
Sorry I can't help with the pics since my cars are small blocks. Classic Auto air did the same crap to me, wrong instructions, no you don't need an idler pulley, don't need a different crank pully, when the stuff showed up I was going to have to change all the parts they said I wouldn't have to I also got b-body instructions which they said was a mistake???  Then they wanted to charge me to take their stuff back. :nono: I hope you have better luck.
Offline pandamarie
  • I love YaBB 1G - SP1!
Re: a/c E-bodys
« Reply #2 on: July 02, 2006 - 11:02:31 AM »
I have a 69 charger and a 70 challenger both with a/c( well use to have it) and they were set up the same way as far as compresser mounting and hose layout. are you using a sanden compresser? Im thinking of putting a/c back on both cars with the sanden compresser but I have the march serpintine set up on both cars and havent seen thier mount yet.
1938 packard 120
1948 lincoln convertible coupe(1 of 16)
69 charger
70 challenger R/T 440 6 pac
71 challenger 340 R/T 4 speed
2-1961 nash metropolitans
forgive wifes 75 vette
2002 dakota 4.7
Offline todd383
  • I'm a llama!
Re: a/c E-bodys
« Reply #3 on: July 03, 2006 - 06:07:48 AM »
yea im using the sanden compresser, but i just found out that they gave me the wrong setup,  gave me one for a b-body, i am waiting to call them today,(monday) to give them HELL!!!!!!!but still hope they have better instructions!!!
Offline Tropicalcats
  • Don't Ever, Ever Give Up
Re: a/c E-bodys
« Reply #4 on: July 03, 2006 - 06:22:40 AM »
This might help some http://ridesthatrock.com/html/cooling.html
wait for Rev and Redline to answer your post I'm sure they can help
SOLD
Offline crcarch
  • Happiness is having the time and the money!
  • "No, it's not a Charger!"
    • A little history and restoration pics on Cardomain
Re: a/c E-bodys
« Reply #5 on: July 03, 2006 - 07:11:32 AM »
Also look at http://bouchillonperformance.com/BPEaircondition.asp for info.
Here's a pic of my engine with A/C compressor location.  March pulleys/brackets and Bouchillon/Sanden A/C set-up.
« Last Edit: July 04, 2006 - 12:06:50 AM by Rev-It-Up »
00/===\00 73 Challenger 440-4V/AT  8/--+--\8 09 Ram 1500  0o\==/o0 05 Crossfire Roadster OO(#####SRT)OO 10 Challenger
RedLine
Re: a/c E-bodys
« Reply #6 on: July 04, 2006 - 12:21:03 AM »
There's a differnce between "getting a March Pulley System" and "getting pulleys and brackets from March"
in our case we ordered specific pulleys (from different systems - they sell separate) that matched what we needed to do.  MMSACC made brackets for us out of stainless steel-- and they sell them now... http://www.mmsacc-stainless.com/html/addlmoparitems.htm
Here's a shot of our setup.  Notice we took out our idler pulley and drove the water and PS on same belt.
« Last Edit: July 04, 2006 - 12:25:36 AM by Rev-It-Up »
Offline pandamarie
Re: a/c E-bodys
« Reply #7 on: July 04, 2006 - 08:36:36 AM »
Some nice A/C setups here using the sanden compresser. I have the march serpintine pullies with the billet brackets and would like to see thier billet brackets for the a/c for that. Ive had my march system on since they first came out with it and dont want to change to different brackets. I have a couple sanden compressers sitting around. also need it to work with the 6 pack intake.
1938 packard 120
69 charger
2002 dakota 4.7
Offline miketyler
    • www.miketyler.net
Re: a/c E-bodys
« Reply #8 on: July 04, 2006 - 10:44:12 AM »
are your cars BB or SB engines? If you are going Sanden on a small block and intend to use March equipment your option will be somewhat limited compared to the BB solutions. Bouchillion will tell you his systems require his pulleys. I am not sure how close to stock they are.
I did like Rev and Redline and had to fabricate brackets to work with the March system. My problem was compounded by the later model Mopar Performance intake with passenger side offset t-stat housing. This t-stat housing on this manifold is located in the area where most SB folks park their Sanden compressors.
I became obsessed with a dual drive belt system with no idler pulleys and ended up having a custom dual v-groove water pump fabricated. Looks just like the March product, only with 2 grooves.
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline todd383
  • I'm a llama!
Re: a/c E-bodys
« Reply #9 on: July 04, 2006 - 04:08:37 PM »
thanks for the replys. I think classic air is closed for the week, hopefully, they will be at carisle. But what im lookin for is a set up like the way way the factory did,  in the stock locations , my car has a/c from the factory, but what i want is the same type condenser, and the way the factory ran the hoses, I just want a easy bolt in deal, some times i do not want to use my brain power to figure something out. I like EASY!!! but idont know if anybody does that??? does anybody know??
Re: a/c E-bodys
« Reply #10 on: July 04, 2006 - 04:11:01 PM »
I'm with you buddy, but I have no answer.  :-[
Offline miketyler
    • www.miketyler.net
Re: a/c E-bodys
« Reply #11 on: July 04, 2006 - 06:17:28 PM »
If your car is a factory AC car with all the trimmings they make a kit to swap out the RV4 to Sanden. Its a simple bracket that mounts the Sanden in the RV4 saddle. I don't know much more than that but I have seen them on Ebay. they look like this:
72' Cuda restomod
70 Mustang Mach 1
Offline Robb
Re: a/c E-bodys
« Reply #12 on: July 04, 2006 - 11:08:52 PM »
http://www.paddockparts.com/Paddock/productr.asp?pf%5Fid=CAA134&gift=False&0=dept%2Easp%2Cdept%5Fid%3D4%26menu%5Fid%3D%26Tree%3D%2CDodge%2FPlymouth&1=dept%2Easp%2Cdept%5Fid%3D63%26menu%5Fid%3D%26Tree%3D0%2CDodge%2FPlymouth%20Heating%20%26%20Cooling&2=product%5Ffamily%2Easp%2Cfamily%5Fid%3D1649%26Tree%3D1%2CMopar%20Sanden%20Air%20Conditioning%20Conversion%20Kits&HSLB=False&mscssid=ADE03B6A7031494FB8542977178A178A
schwewwww   hope I typed that right.
66-78 MOPAR SADEN A/C CONVERSION KIT
WITH THE AGING OF ANY MOPAR MUSCLE CAR, THE AIR CONDITIONING SYSTEM IS NOT ALWAYS UP TO SNUFF. WE OFFER THIS CONVERSION KIT SO YOU CAN REPLACE THE ORIGINAL COMPRESSOR AND COMPONENTS WITH THIS NEW LIGHTWEIGHT EFFICIENT CONVERSION KIT. CONSTANT DUTY RATING IS 6,000 R.P.M. A LOW HORSEPOWER DRAW IS ALSO A GREAT FEATURE. THE KIT IS COMPLETE INCLUDING FILTER DRIER AND HOSES MADE FOR EACH SPECIFIC YEAR AND MODEL. KITS ARE AVAILABLE FOR R-134 OR R-12 REFRIGERANTS. THESE KITS ARE EASILY INSTALLED AND ARE CLASSIFIED AS A DIRECT BOLT ON SYSTEM. FOR 440 ENGINES WITH FACTORY AIR. PLEASE SPECIFY YEAR AND MODEL OF CAR. DROP SHIPPED DIRECTLY FROM MANUFACTURER. PLEASE ALLOW UP TO SIX WEEKS FOR DELIVERY. MUST BE PREPAID BY CHARGE CARD, CHECK OR MONEY ORDER. NO FURTHER DISCOUNT APPLIES. ITEMS SHIPPED OVERSIZE.
Product Number CAA134
Price:$499.95
Miscellaneous Charge for OVERSIZE: $29.90
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
Offline Robb
Re: a/c E-bodys
« Reply #13 on: July 04, 2006 - 11:14:27 PM »
Miketyler.........
RV-2 or RV4 ?
Offline miketyler
    • www.miketyler.net
Re: a/c E-bodys
« Reply #14 on: July 05, 2006 - 05:01:19 AM »
I might be confusing the name of the stock Mopar compressor with that of a homebuilt airplane. It may indeed be RV-2?
72' Cuda restomod
70 Mustang Mach 1
