So its summertime when everyone is supposed to be working on their mope's
Author Topic: So its summertime when everyone is supposed to be working on their mope's  (Read 2567 times)
Offline RusTy/SE
  • Just havin' fun
 :bigsmile:
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Offline RusTy/SE
  • Just havin' fun
  Just thought of something but i'm probably grasping at straws...several days ago i rinsed down the engine bay on the Coronet and as it has that asbestos (?) wrap on the headers maybe that would explain my "smoke" (trapped moisture). Maybe trapped moisture still hasn't evaporated  ::) Still doesn't explain that wisp from the distributor area though :walkaway:
Edit: Joe (Slimer) just stopped by and agreed to look under the hood as i tried to start the Coronet - fired right up with nary a hint of smoke although we could now barely make out the "smell" of moisture. The wisp from the distributor area was from some moisture trapped under the dist. cap.  :woohoo: :woohoo: :clapping:
Today's lesson learned - don't get water on wrapped headers. :bricks1: :bricks1:
Thanks Mike :2thumbs:
« Last Edit: July 04, 2006 - 03:45:02 PM by RusTy/SE »
Russ
2001 Durango     1B4HS
Offline GoodysGotaCuda
Yeah, you're right, its not the heat....its that stinkin humidity lol
If i have to hear that one more time....lol. i lived in virginia two summers ago, hampton roads area and it was hot and humid. very, had no a/c in my mustang either. And now i live where its been 113* already and hot is hot after about 102*ish...wet or dry heat, i dont care...its hot.  :lol:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Denso alt is in as promised, its the same color as the intake but looks super white for some reason  :woohoo:
Yes, i know i need to clean up under the hood. its my daily, gimme a break.  :lol:
1976 Dodge Warlock
daves70
Looks better than some I've seen!! :grinyes:
Offline EVIL72
 Over the weekend I installed a swap meet clutch fan, Edelbrock Air-Gap RPM intake, with a 1" Super Sucker Carb spacer, an old 700 Holley double pumper, Lokar cable kickdown linkage, along with taller throttle linkage, a 3" K&N Air Filter and X-Stream Air Flow top, and some new valve cover gaskets, because my not that old reusable ones decided they didn't want to be reused after all.
 I still have to install my new Pertronix Flame Thrower II Coil as soon as I remember where I put the new coil bracket I've had laying around for years at, and fix the leak from the freakin Chrome water neck.....
Hopefully I'll have time this weekend to recurve the distributor too.
ROB
1972 Dodge Challenger 340ci
1970 Pro Street Duster (Under Construction)
Offline rtgambit
  • Member since March 31, 2003
Looks like the alt is sitting in almost direct sunlight. The camera is set to Center-weighted metering, so it's trying to provide the best exposure for the area around the intake and air cleaner.  :eek7:
Sorry - I'm at work so I'm in tech support mode (Nikon digital cameras).
Matthew
1967 Dodge Dart GT
1971 Dodge Challenger R/T
2014 Ram 1500
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Been doing mostly bodywork on the cuda, and it has been getting hot (triple digits!!) I usually have to stop around noon, which really sucks. The car is really coming along, hopefully have more pictures soon, and maybe paint in a few weeks :bigsmile:
1996 Dodge Viper GTS Coupe
Sounds pretty good. Throw that Chrome T-Stat housing as far as you can, sucker will never be leak free...damhik  :villagers:
1976 Dodge Warlock
Offline EVIL72
My thoughts exactly.  :thumbsup:
ROB
Offline 71GTX
  • It's a fine line between a hobby & mental illness!
Mine are on hold until I get myself moved back down to the states....but I am still buying and looking for more.... :naughty:
69 RoadRunner (clone)
70 Cuda 383 4 speed (project) one of the first few off the line at Hamtramck with a 1017XX VIN
70 Cuda convertible 340 4 speed (project)
70 Barracuda (project)
71 GTX 440 4 speed (project)
72 Cuda 340 3 speed (project)
3 Harleys
95 Dodge Ram 2500 Diesel 4x4
Expensive Pee is the end result of Expensive Beer!
Offline ESGEE
  • 1970 Challenger RT/SE
    • SG´s site
My Challenger is just waiting for a fender(should be here next week) then i just put it toghter and ride it some..
My 70 Charger is off for paint(after paint i will change the vinylroof) and then the car should be like new :bigsmile:
My 69 Charger needs allot of welding before it ever get any paint, and change fuellines and tank, it looks like hell but goes like real beast :burnout:
70 Challenger RT/SE(Looking for 383 Magnum N0B196875)
70 Challenger RT/SE(Looking for 383 Magnum N0B115166)
70 Challenger SE(RT/SE clone)
69 Charger RT/SE 4speed Trackpac
70 Charger 500
Welp. after many hours, putting in a new converter by myself for the first time was quite a lovely experience  :lol2:. but it does run! very, very well. went from about 2,500stall no-name converter to a 3,800/3,900rpm flashing 9 1/2" dynmamic. its a little monster now  :jumping:
1976 Dodge Warlock
