Author Topic: Gear swap??  (Read 5210 times)
Offline RAD1229
  • 72 Challenger
Re:Gear swap??
« Reply #15 on: May 15, 2003 - 02:57:40 PM »
 Do you guys think that tuning the carb will change things?  I really have no clue??  I am running an Edlebrock 600 on a Wiend Dual plane intake (Just from parts that were around) I know that You can get more torque from one than the other, i think that mine is built for the horse power.  ??  if there is a carb tuning that will make a difference i would like to hear about it before I Swap back out.  OK thanks guys!
-RAD
1972 Challenger
Offline Robb_Scottsdale
  • self inflicted victim of the ''might-as-well's''
Re:Gear swap??
« Reply #16 on: May 15, 2003 - 04:25:19 PM »
for the carb tuning I was thinking along the lines of, say a Holley Double pumper,  trying some different cams and squirts etc....    my experience there is limited compared to most guys here so....
bummer you didnt get a bigger perf. difference.    :-\
'68 Sport Satellite Convertible (383/4) (B5 blue) Survivor
'70 Challenger SE (383/2) (EK2 orange ) Survivor with light Perf Mods
'98 Ram 1500 Sport Club-Cab 4x4 (360) (all-black) 3in lift, 33x12.
Offline RAD1229
  • 72 Challenger
Re:Gear swap??
« Reply #17 on: May 15, 2003 - 05:27:26 PM »
  Very little perf. differenve ???   I am running a 484 lift cam with 292 lift.  but i can barely scratch the tires from a start.  I do have 3 speed auto tranny though (727).  If i was running a 4 sppen manual I know things would be different.   I can tell that I run at higher RPM's but with the higher gears (2.76) I can use more of second.   Both sets of gears do get a real good scrath when I bump it into second, and will somewhere between 85-90 in 1/4.
I am not disapointed in the performance, just thought it would make more of a difference.
- RAD
1972 Challenger
Re:Gear swap??
« Reply #18 on: May 16, 2003 - 04:48:34 AM »
Actually with big blocks it rarely does , my Duster ran 12.0 in the 1/4 with 3.23 & 11.7 with 4.30
Re:Gear swap??
« Reply #19 on: May 16, 2003 - 12:55:45 PM »
My experiences that I was reflecting on were a few chebbie 350's a 307, and a fxrd SB too...
they were 27x-29x hwy gears going to 3.5x and 3.7x  but man, it seemed like they were night-day differences at the time.
I have an open differential now and need SureGrip/Posi anyway....   I was holding out for 3.55 but shoot, maybe Ill just run 3.23 if there isnt going to be a noticeable difference on the streets.
 :-X
Re:Gear swap??
« Reply #20 on: May 17, 2003 - 05:09:42 AM »
Carb tuning can help if it is not tuned correctly , they rarely are
