I had the same problem. Chris helped and got it MUCH better but we both weren't satisfied and knew that the one person that could do it would arrive shortly, Chryco. He got the hood dead on on the second try (about 3 minutes).
To get the hood right, you will need 2 people. One person to loosen the hinge botls while another person holds the hood in adjustment.
I would loosen all 6 hinge bolts and close the hood to be sure it can lay flat. After confirming it is possible, one person should lift up on the edge of the hood causing the single bolt slot to raise while the 2 botl slots in teh back lower, your helper will then tighten down the bolts. from there it is a matter of trail and error, but at some point you will be barely loosen the rear top bolt so it can be a pivot point.
I can try to explain better if needed and post a pic. Maybe Chryco will read this and offer his advice as mine maybe confusing.
