Author Topic: Whats the biggest rim/tire you can run on the rear of a 70/71 cuda?  (Read 1961 times)
Offline 71chally383R/T
Whats the biggest rim/tire you cn run on the rear of a 1970/1971 cuda ???
(will 15 x 10 w/345/50/15 w/5inch backspace fit on the rear if you have a 3'' spring re-location on the back?)
Re: Whats the biggest rim/tire you can run on the rear of a 70/71 cuda?
« Reply #1 on: July 03, 2006 - 11:55:21 PM »
Generally a 295/50/15 on an 8" rim with a 4" backset
« Reply #2 on: July 04, 2006 - 01:34:13 AM »
do you by any chance have a pic of this size?
Offline 360 'CUDA
« Reply #3 on: July 04, 2006 - 10:42:48 AM »
Here is a pic of mine but it had 10" wheels with the bolt on rear spring relocator... 5" backspace
Offline gomopar440
« Reply #4 on: July 04, 2006 - 01:16:02 PM »
Umm... Where's the pic? ???
« Reply #5 on: July 04, 2006 - 01:54:53 PM »
 :useless:
   :useless:
      :useless:
Offline inot2old
« Reply #6 on: July 04, 2006 - 04:27:34 PM »
My buddy has 30X12.5 on his '70 Cuda.  I don't know what size wheel or backspacing.
'71 Cuda
'70 Charger project
'05 Crossfire Roadster
Offline 360 'CUDA
« Reply #7 on: July 05, 2006 - 12:08:39 AM »
 :blah:  :blah: OK more pics  :blah:  :blah:
Offline ntstlgl1970
  • T a c o c a t
« Reply #8 on: July 05, 2006 - 01:12:09 AM »
17x9.5
305/45R17
offset hangers, rolled fender lip 6.9" backspace 3/4' spacer longer studs
without working the outer edge of the inner wheel well this works out ok. I like having the tires tuck up in the wheel well, if you don't want that look you can go wider I think with the ride height higher
I think "will 15 x 10 w/345/50/15 w/5inch backspace fit on the rear if you have a 3'' spring re-location on the back?" would work fine if you cut the wheel wells open some (the inner portion). Seems like when you get around the 29-30" diameter tires you might have to lengthen the opening of the wheel well depending on if you are going to run slicks/bias plys or they might rub on the top end at the track.
Offline gomopar440
« Reply #9 on: July 05, 2006 - 01:48:20 PM »
For the looks of those pics, your old tires must have gone out in a blaze of glory. :ylsuper: :clapping:
Offline 71fish
  • Bless you..
    • Ken's 71fish
« Reply #10 on: July 05, 2006 - 01:56:15 PM »
I have N50's on the rear. Big boots for sure. 15" rim of course.
71fish - Nobody better than an E-BODY!!
