Author Topic: Another "How To" added to the lamopar.com site... Door Hinges.  (Read 1666 times)
Offline Cuda Cody
  • Vancouver, WA
While I wait for more wiring harnesses to be delivered, I went ahead and fixed my sagging doors.  They were really bad!   :scared:  Check out the videos of before and after.
http://www.lamopar.com/How%20To%27s/Door%20Hinges/index1.htm
 :2thumbs:
Offline EvilTwinATX
Re: Another "How To" added to the lamopar.com site... Door Hinges.
« Reply #1 on: July 06, 2006 - 10:37:49 PM »
 :wow: Man, Cody...you do great writeups!
One thing though....I always figured you for a tighy-whitey guy though!!  :roflsmiley: Hint: 370.jpg :bigsmile:
Offline 71fish
  • Bless you..
    • Ken's 71fish
« Reply #2 on: July 07, 2006 - 06:10:52 AM »
CODY - awesome rebuilding guide you put together. I saved that one. Great work.. step by step.  Perfect!
Thanks
71fish - Nobody better than an E-BODY!!
Offline Cuda Cody
  • Vancouver, WA
« Reply #3 on: July 07, 2006 - 02:23:12 PM »
I save and use everything for rags!  I didn't see that in the pics.  oops.
They did start out white.....  :roflsmiley:
« Reply #4 on: July 07, 2006 - 02:49:05 PM »
Cody, what part is it that makes the steering wheel lock? Mines broken and I need to get that part and what it looks like before I tear it apart.
Offline Cuda Cody
  • Vancouver, WA
« Reply #5 on: July 07, 2006 - 03:19:28 PM »
That's hard to say what part it is.  It's not just a single part or even two parts that make the locking system work.  The key moves a lobe that moves a lever that releases the notched sprocket that is pinned to the steering shaft and that allows the steering wheel to unlock.
I would suggest taking it out and inspecting it prior to purchasing any replacement parts.  It could be something simple that just came undone or apart.  As for the parts that make it work, here are the pieces that make it lock.....
http://www.lamopar.com/How%20To%27s/Steering%20Column/pages/DSC01132_jpg.htm
and this is the piece that locks into the above pictured part....
http://www.lamopar.com/How%20To%27s/Steering%20Column/pages/DSC01143_jpg.htm
and this is the spring that keeps presure on it.....
http://www.lamopar.com/How%20To%27s/Steering%20Column/pages/DSC01151_jpg.htm
This is the part cleaned up and going back in.....
http://www.lamopar.com/How%20To%27s/Steering%20Column/pages/DSC01409_jpg.htm
You can see the lobe in this picture.    The key is what turns the lobe and releases the lock.
http://www.lamopar.com/How%20To%27s/Steering%20Column/pages/DSC01414_jpg.htm
This is the cover to the lever....
http://www.lamopar.com/How%20To%27s/Steering%20Column/pages/DSC01416_jpg.htm
Although this pic is showing the "C" clip, look up in the right hand corner and you will see how the lever lock to the notched sprocket.....
http://www.lamopar.com/How%20To%27s/Steering%20Column/pages/DSC01435_jpg.htm
Hope that helps!  Good luck  :thumbsup:
« Reply #6 on: July 07, 2006 - 03:28:37 PM »
Thanks Cody. it was if someone used force at some time in the past to get the steering wheel to turn. Probably broke off one of those bolts then.
« Reply #7 on: June 12, 2008 - 09:57:26 AM »
Cody, We sure do miss your how to articles, are these availabale anywhere else?
Wade
Offline MrMopar440
« Reply #8 on: June 12, 2008 - 10:03:48 AM »
 :iagree: :iagree:
It looks like you have done a great job documenting the things you did from all the posts I read.  :worshippy But now I need to use them too
